You can't use Filetransfer on your server, without an opened port for it.
And 30033 TCP is the default port for it.
I can upload them now but the icon will change if I modify permission is insufficient power
and I have Server Admin.
You need enough i_permission_modify_power and the grant value behind b_ and this grant value needs to be equal or higher as your i_permission_modify_power.
Login into the query admin ,when you have access to it and set this permission to your group
This is the command you need to add the grant value.
Code:servergroupaddperm sgid=yourgroupidhere permsid=i_needed_modify_power_icon_manage permvalue=75 permnegated=0 permskip=0
where do I write the command?
could you give me a detailed instructions?
Silv3r162 - Your question getting off-topic, can you use the search function please?
http://forum.teamspeak.com/showthrea...253#post288253
It may be that I must do it differently? I have the ts3 server on my pc windows so here
Hi everyone, my friend and I are having trouble uploading icons to our TeamSpeak 3. We do not know what is wrong, or how to fix it. When we go into the Server settings and then to "View Icons", when ever we try to upload one, it says this:
<14:26:31>
Transfer "icon_588148524" reports: (could not open file transfer connection)
<14:26:53>
Transfer "icon_1886981478" reports: (file transfer connection timeout)
Someone please help, Thanks, Bobby and Brandon of SRA
Please provide us more informations
Where is the Teamspeak server ?
The filetransfer port is open - 30033 (TCP) ?
Info : this question has been answered many times on this forum. Next time please use the search function.
So i recently made my own TS server, but theres a problem with icons.
whenever I try to upload an icon it says : Transfer 'icon_3281584774' reports: (could not open file connection)
can u guys please help me?
First, this belongs in the support section.
And second, you need to open the port that allows you to upload files/icons which is 30033 TCP
i entered this into the query and it says im band wtf im the super admin i pay for the server so why does it says this
error id=3329 msg=connection\sfailed,\syou\sare\sbanned extra_msg=you\smay\sretry\sin\s376\sseconds (1 ms)says this after i enter the code u said to use servergroupaddperm sgid=entergroupidhere permsid=i_needed_modify_power_icon_manage permvalue=75 permnegated=0 permskip=0
This happens, when you spam to many commands in a row. It doesn't matter, that you are the Server Query Admin as lonmg your Ip is not entered into the whitelist.txt
Transfer "icon_1997939459" reports: (file transfer connection timeout) i keep getting this when i try to load icons into ts. also i can see the icons some members can and others cannot see the icons any help or information with this would be helpful thank you
*** Thread Merged ***
Today I created a server on my computer but when someone on another computer tries to put the icons in a server error: Transfer "icon_3621565682" reports: (Could not open file transfer connection). But the server I can put the icons and an SA on another computer can not, someone would have the solution for this error.
ERROR: Transfer "icon_3621565682" reports: (Could not open file transfer connection)
You need forward port 30033_TCP to your server.
