Page 4 of 9 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 126
  1. #46
    December 2011
    13
    When i try to upload an icon for my channels it says like this :
    <09:19:25>
    Transfer "icon_691087410" reports: (could not open file transfer connection)
    and thanks
    Edit by mod
    Post moved in the good thread.
  2. #47
    December 2011
    13
    <01:55:41>The icon for channel "World of Warcraft" (14) was not found.
    <01:55:41>The icon for channel "Counter Strike Team 1" (3) was not found.
    <01:55:41>The icon for channel "Star Wars The Old Republic" (7) was not found.
    <01:55:41>The icon for channel "General Zero Hour Team 1" (5) was not found.
    <02:01:38>Transfer "icon_1827911473" reports: (could not open file transfer connection)
    <02:01:38>Transfer "icon_1081394037" reports: (could not open file transfer connection)
    <02:01:38>Transfer "icon_4219603380" reports: (could not open file transfer connection)
    <02:01:38>Transfer "icon_1445341113" reports: (could not open file transfer connection)
    <02:01:38>Transfer "icon_2253346527" reports: (could not open file transfer connection)
    i keep getting that
    any idea what to do?
    *** Thread Merged ***
  3. #48
    January 2012
    I was having this problem, had forgotten to release the gate 30033, in my case resolved thereafter.
  4. #49
    January 2012
    Im running a TS3 with my PC
    Im running a teamspeak 3 server by portforwarding but the icons don't work...what ports do i have to use to get icons on my teamspeak to work?
  5. #50
    February 2012
    Icons are not uploading
    Transfer "icon_2849359603" reports: (could not open file transfer connection)
    Port 30033 is open & is accessible.
    The file creates but the size is 0 bytes then it deletes after a short period of time.
    Thank you.
  6. #51
    February 2012
    Owner,
    Could you let me know any permissions that would effect this?
  7. #52
    February 2012
    Angry Transfer "avatar" berichtet: (could not open file transfer connection)
    *** German part deleted ***
    *** This forum is english only. ***
    I folgenes problem, I have my own server, but every other member of the server can put on this is not Avatar, among them is always set to "Transfer" avatar "reported: (could not open file transfer connection)" one and only at the where is it I am but I'm also on "localhost" into the ports 30 033 30 034 udp udp and tcp as the 30 033 and 30 034 tcp I have switched to free as in my router and when I win fire wall. Perhaps you have ideas how I could still ne the problem get out?
    Gruß Rewada
  8. #53
    March 2012
    Unhappy <18:03:42>  Transfer "icon_1068354241" reports: (could not open file transfer connect
    Ok so im trying to put new icons that i got from here(green/grey/red) but when i try to upload them i get this error:
    <18:03:42>  Transfer "icon_1068354241" reports: (could not open file transfer connection)
    anyone know a fix for this?
  9. #54
    March 2012
    Solved Server Icons not working!
    Hello I have a Teamspeak Server and I have the Server on my Computer.My friends can connect on the Server.I have uploaded some Icon Packs and I use them for different Server groups but my friends can't see the icons.I am the only one who can see them and I need somebody who can help me.
    Teamspeak Client: Teamspeak 3
    Server Version: teamspeak3-server_win64
    I hope somebody helps.
  10. #55
    18,037
    We miss informations like, is your port for filetraqnsfer opened? And what error do your users get?
    http://forum.teamspeak.com/showthrea...ighlight=Icons
  11. #56
    March 2012
    Thanks for replying dante696.I know what the error was and now I've managed to fix it.I forgot to open the filetransfer port.
  12. #57
    November 2012
    Cant upload icons
    i seem to be having trouble uploading icons.
    i get this error every time i try
    <22:18:40> Transfer "icon_181172533" reports: (file transfer reset)
    <22:19:01> Transfer "icon_181172533" reports: (could not open file transfer connection)
    no clue what to do. thanks in advance
  13. #58
    November 2012
    i opened the transfer port but i still get the same error. does it need a reboot?
  14. #59
    6,076
    TCP Port 30033 (by default - can be changed) needs to be open and - in case of NAT - be forwarded to the correct ip.
    After that it should work. Maybe you opened it as UDP? A reboot never hurts but shouldn't be necessary at all.
  15. #60
    April 2009
    7
    I am having the same issue. As far as server query and the actual voice server goes, it's working fine. But anything to do with 30033 is not working. I do have everything forwarded through my firewall, and reboots have been attempted on both firewall and server. Here is the netstat from my server for more information (without the MySQL and irrelevant connections):
      TCP    192.168.1.143:10011    Ares:0                 LISTENING
     [ts3server_win64.exe]
      TCP    192.168.1.143:30033    Ares:0                 LISTENING
      UDP    192.168.1.143:2011     *:*
      UDP    192.168.1.143:9987     *:*
      UDP    192.168.1.143:9988     *:*
      UDP    192.168.1.143:9989     *:*
    I should also add that I can see other traffic from the internet on that IP and port, it just seems to be the filetransfer that is having issues.
  1. Replies: 2
    Last Post: July 16th, 2018, 06:01 PM
  2. Replies: 4
    Last Post: March 11th, 2013, 02:11 AM
