Results 1 to 4 of 4
    July 2011
    Solved Problem Linux Centos
    Welcome
    I have a problem with TeamSpeak 3 server.
    CentOS Linux system (VPS)
    Downloads sometimes unpacks everything goes successfully.
    Starts the server generates the ServerAdmin and password and token
    Starting Teamspeak combine everything works.
    Disable your copiuje licensekey.dat run the server, here the problems begin the server will not start
    The first error
    2011-07-14 11:06:51.259075 | INFO | ServerLibPriv | | Server Version: 3.0.0-rc1 [Build: 14468], Linux
    2011-07-14 11:06:51.259621 | INFO | DatabaseQuery | | dbPlugin name: SQLite3 plugin Version 2, (c) TeamSpeak Systems GmbH
    2011-07-14 11:06:51.259665 | INFO | DatabaseQuery | | dbPlugin version: 3.7.3
    2011-07-14 11:06:51.267933 | INFO | DatabaseQuery | | checking database integrity (may take a while)
    2011-07-14 11:06:51.311099 | INFO | SQL | | pruning old database log entries WHERE timestamp is older than 90 days
    and sometimes shows
    On Unix it terminates the server on startup and the message reads "Server () error while starting ServerManager, error: instance check error". How do I fix this?
    As long as you do not have a license key embededded we make sure you only run one instance of exactly the TS3 server free unregistered version. We use shared memory to Facilitate the communication to detect other instances running, Which requires tmpfs to be mounted at / dev / shm. If you (for whatever reason) to not have this mounted, the above error will occur.
    To fix this problem, the Following commands or file edits need to be done as root user (or using something like sudo). This is a temporary fix until your next reboot.
    mount-t tmpfs tmpfs / dev / shm
    Now, to make sure this is done automatically mount upon reboot edit the file / etc / fstab and add the line:
    tmpfs / dev / shm tmpfs defaults 0 0
    I made as written and still not working
    May 2010
    6,310
    Do you get any other error message (post the entire server log) ?
    When you send the mount -t command, do you get an error ?
    If not, after this command, your server start normaly ?
    (subsidiary question, the port 2008 TCP is open?)
    September 2010
    Aus
    6
    I recently reinstalled my VPS, it updated to (ubuntu-10.10-x86_64) from (ubuntu-9.10-x86_64).
    I was using
    "tmpfs /dev/shm tmpfs defaults 0 0"
    in /etc/fstab but it would not automount!
    I removed
    from /etc/fstab, i replaced it with the following:
    shm        /dev/shm        tmpfs   defaults,size=256M      0       0
    Now it works!!
    I would suggest if others are finding this works the quick start.txt will need to be amended.
    June 2013
    29
    Quote Originally Posted by dvs12c View Post
    I was using
    I removed
    Now it works!!
    Thank you - and you're right. they need to put that in there.
  1. [Not possible] Music Bot on linux Centos with SSH
    By Razgriz in forum Linux
    Last Post: August 13th, 2014, 02:01 PM
  2. Linux CentOS
    By Joele25 in forum Linux / FreeBSD
    Last Post: April 4th, 2014, 08:29 AM
  3. Help with Linux centOS, libmysqlclient.so.16
    By rossco in forum Linux / FreeBSD
    Last Post: July 31st, 2011, 04:25 PM
  4. Problem Linux Centos
    By korn27a in forum Linux / FreeBSD
    Last Post: July 14th, 2011, 01:14 PM
  5. Problem Linux Centos
    By korn27a in forum Server Support
    Last Post: July 14th, 2011, 01:12 PM
