Results 1 to 4 of 4
Thread: TSDNS problem
    July 2011
    TSDNS problem
    I can connect to the public teamspeak and such just fine. However, when i try to connect to my friends it just get this error message
    <18:28:43> Trying to resolve hostname ts.tsugaming.com
    <18:28:44> Trying to connect to server on ts.tsugaming.com
    <18:28:50> Failed to connect to server
    here is the client log if that helps any
    7/17/2011 6:23:58 PM Info Logging started, clientlib version: 3.0.0-rc2 [Build: 14642]
    7/17/2011 6:23:58 PM Direct Sound Debug setting timer resolution to 1ms
    7/17/2011 6:23:58 PM Info Registering plugin command id: {a8929d87-7f4e-4c07-8b28-ea35b12d7798} appscanner_plugin
    7/17/2011 6:23:58 PM Query Info listening on 127.0.0.1:25639
    7/17/2011 6:23:58 PM Info Registering plugin command id: {873281d5-9f78-4617-8ec4-77ac7b9f4bfb} clientquery_plugin
    7/17/2011 6:23:59 PM GenericPlayback Info STOPWATCH1 closePlaybackDevice: 0 ms -1
    7/17/2011 6:23:59 PM Input Info Input device name: Mouse
    7/17/2011 6:23:59 PM Input Info Input device name: Keyboard
    7/17/2011 6:24:00 PM ClientUI Info TeamSpeak 3 client version: 3.0.0-rc2 [Build: 14642]
    7/17/2011 6:24:00 PM ClientUI Info Qt version: 4.7.2
    7/17/2011 6:24:00 PM ClientUI Info Using configuration location: C:/Users/Shaun/AppData/Roaming/TS3Client/ts3clientui_qt.conf
    7/17/2011 6:24:00 PM ClientUI Info Last update check was: Sun Jul 17 00:04:10 2011
    7/17/2011 6:24:03 PM GenericPlayback Info STOPWATCH1 closePlaybackDevice: 0 ms -1
    7/17/2011 6:24:03 PM Windows Audio Session Debug WAS:penDevice-enter
    7/17/2011 6:24:03 PM Windows Audio Session Debug WAS:penDevice-leave
    7/17/2011 6:24:03 PM GenericPlayback Info STOPWATCH1 internalOpenDevice: 58 ms -1
    7/17/2011 6:24:03 PM Windows Audio Session Debug WAS::startDevice-enter
    7/17/2011 6:24:03 PM Windows Audio Session Debug WAS::startDevice-leave
    7/17/2011 6:24:03 PM GenericPlayback Info STOPWATCH1 internalStartDevice: 0 ms -1
    7/17/2011 6:24:03 PM GenericPlayback Info STOPWATCH1 openPlaybackDevice: 59 ms -1
    7/17/2011 6:24:03 PM GenericPlayback Info STOPWATCH1 closeCaptureDevice: 0 ms -1
    7/17/2011 6:24:03 PM GenericPlayback Info STOPWATCH1 internalOpenDevice: 63 ms -1
    7/17/2011 6:24:03 PM PreProSpeex Info Speex version: speex-1.2beta3
    7/17/2011 6:24:03 PM GenericPlayback Info STOPWATCH1 internalStartDevice: 1 ms -1
    7/17/2011 6:24:03 PM GenericPlayback Info STOPWATCH1 openCaptureDevice: 68 ms -1
    7/17/2011 6:24:16 PM Info TSDNS found at "voice.teamspeak.com" and queried successfully. Result: 194.97.114.2:9987
    7/17/2011 6:24:24 PM Info No TSDNS found at "ts.tsugaming.com"
    any help would be wonderful thanks.
    May 2010
    6,310
    This not because you get this message that it's necessarely a TSDNS problem.
    It just indicates that there is no tsdns server for this domain name.
    You can try directly with the IP address (instead the doamin name) : 173.193.83.36
    Maybe it's just a Internet DNS problem.
    (Both works for me)
    July 2011
    Seriously no one has any words of help. What kind of support forum is this if you don't get a answer? A pitiful one.
    May 2010
    6,310
    Quote Originally Posted by Tiranous View Post
    Do you read my previous answer ?
    Let me repeat myself :
    This not a TSDNS problem, because this no tsdns server for this address.
    I can connect on this server and I have this message too :
    2011-07-21 01:48:18.070284|INFO    |              |   | No TSDNS found at "ts.tsugaming.com"
    2011-07-21 01:48:18.080299|INFO    |              |   | No TSDNS found at "tsugaming.com"
    This not an error message but an information
    It's a DNS problem (or IP "request" problem)
    If the spread of the domain name (IP <-> domain) did not come up to you, nobody can do anything.
    Just wait, this is an Internet problem.
  1. TSDNS problem
    By Andevi97 in forum Windows
    Last Post: September 22nd, 2014, 05:49 PM
  2. Big Problem, TSDNS
    By Tryton in forum Server Support
    Last Post: December 2nd, 2013, 02:15 PM
  3. Replies: 0
    Last Post: August 4th, 2013, 01:52 PM
  4. TSDNS problem
    By Dream in forum Server Support
    Last Post: March 19th, 2013, 06:38 AM
  5. TSDNS problem
    By erikz in forum Linux / FreeBSD
    Last Post: June 15th, 2011, 07:52 PM
