Results 1 to 7 of 7
    July 2011
    Send message per Hotkey?
    Is is possible to send a message to the channel via hotkey?
    like: i press 5 and it posts "Hi" in the Channel im currently in?
    May 2010
    6,310
    You can do it, using a little plugin. An example with the lua plugin (2 files) :
    Plugin side
    init.lua
    require("ts3init")                    -- Required for ts3RegisterModule
    require("chanmsg/msgfunc)     -- Function file
    -- Register the callback function
    ts3RegisterModule("chanMsg", registeredEvents)
    Now the msgfunc.lua
    require("ts3defs")
    require("ts3errors")
    function hello()
              local message = "Hello guy how are you ? "
              ts3.printMessageToCurrentTab(message)  -- There is another function, but this is a simple example ;)
    end
    chanmsg = {
              hello = hello
    Now go on your client installation > plugins > lua_plugin > create a new folder named "chanmsg" and put these 2 files in this folder.
    Now Client side
    To use this plugin, you have to write this command line in the chat area :
    /lua run chanmsg.hello (/lua run hello - works too)
    To use a key
    Settings > Options > Hotkeys part
    On the Profile detail part (the key list), click on Add button.
    In the setudp dialog, clieck on Show Advanced Actions
    => Plugin > Run Plugin Command > Select a key and write the command (/lua run .....)
    Save all and voila.
    July 2011
    hi florian
    first: thanks for your help
    but :P
    when i type "/lua run chanmsg.hello" he says Error running Lua function: Module 'chanmsg' not found
    when i type "/lua run hello" he says Error running Lua function: Function 'hello' not found
    May 2007
    Eastern NC
    1,794
    open the hotkey setting and look at it again. I know that sometimes if you have "too long" of command string in the hotkey window it will trim it to a portion of the command and cause problems. If this is the case you can close TS3 and open the hotkeys.ini and manually put the missing part of the command back and it will work.
    May 2010
    6,310
    Also, check if the lua plugin is activated
    Settings > Plugins > check lua plugin > click on settings buton > check the chanmsg plugin
    February 2017
    Looking for something similar. I just need a hotkey to put my cursor in the text box. Or Paste and send with hotkey would work also. Thanks! And sorry for late post.
    March 2019
    Serbia
    8
  1. Send channel message with Hotkey
    By Floflobel in forum Client Plugins / Lua Scripts
    Last Post: April 2nd, 2019, 03:07 PM
  2. How to send message on web?
    By Dream592 in forum Off Topic
    Last Post: September 24th, 2015, 01:13 PM
