Results 1 to 13 of 13
    July 2011
    Solved Channel Create "needed channel delete power" is not 0
    I have encountered what seems to be a bug in "needed channel delete power":
    When creating a channel, the default value of "needed channel delete power" is 0, as it is appeared in the channel creation window, permissions tab. However, after creating the channel, it is created with a non-0 value.
    This is a new problem, I think from the latest TS3 update.
    Is it indeed a bug or did I miss something here?
    Any help is appreciated!
    18,513
    This does not look as a bug.
    You need to know the permission value of 0 or not set means the same.
    July 2011
    I think you misunderstood me: I was expecting to see 0 (or better: not set), but instead I got 75 or 50, according to the user that created the channel. Normal user got 50; I, as server admin, got 75.
    By the way: other setting on the same window, which I left as 0, were indeed "not set" - as expected.
    So if "not set" or 0 is the expected behavior of this setting, then this does look like a bug.
    18,513
    I'am sorry, you did not say, what value has seen set in the dialog.
    Yes this is a bug a ticket has been made already. I found it during permission tests.
    Internal Ticket ID TS-604
    Update this will be fixed with the new serve release (newer as Build: 14876])
    October 2010
    Warsaw / Poland
    296
    Version:
    3.0.0 [Build: 14898] on Linux
    Still not fixed, just saying if somebody is interested :P.
    New England USA / Marnbach, Weilheim i.OB, Germany
    428
    I don't see a problem here..I sort of like that it works this way. Since I have a channel delete power or 75, channels I create have a needed delete power of 75 so no other user with lesser powers can delete channels that I create. If you personally do not like this on your server, set all of your channel delete powers to 0 or something? Who knows. I like it :-)
    October 2010
    Warsaw / Poland
    296
    Yep, I did it aswell as temporary fix for my teamspeak server. But it's not nice trust me :P.
    428
    It's similar to the idea of, when creating a new server group, it is automatically assigned the needed member add power of the member add power of whoever created that group. That is, at least, how I see it :-)
    18,513
    This needs to be discussed later.
    Internal Ticket ID: TSEVAL-50
    July 2011
    I see that this issue is not resolved yet...
    -{HGH}-GEN.Skylab,
    There is a problem here since as I wrote, when you create a channel you can set there the needed channel delete power. This number is 0 by default. So when a user creates a channel he expects the needed chaneel delete power to be indeed 0 (or not set, which is the same). However, the real needed delete power is something else.
    So, regardless on high level ideas and concept - this is a bug since the numbers just don't match.
    2,029
    I too like that a new channel is created with a needed_delete_power and needed_permission_modify_power of the person who creates the Channel.
    In my opinion the Bug is that in the Permissions Tab those Values are not displayed by default. So when a Serveradmin creates a channel it says 0 in the Permissions Tab instead of 75 for the Delete Power, if the Value then gets changed from 75 to something else this should of course be reflected in the actual Channel that gets created which already is the case. In fact if you enter any Value but 0 that value is taken. Its just that if its 0 it takes the one from the Server group which is indeed not that nice if you think about it. If it displayed the Value from the Servergroup in the Permissions Tab and then when creating the Channel use whatever Value is in the Permissions Tab it'd be all fine.
    edit: @dante yeah I know, just wanted to throw in my pov / 2 cents
    18,513
    There is already an ticket for this and currently we don't see this as a bug.
    18,513
    Update for this behavior > This is no bug
    We have discussed about the situation and possible changes, but this won't be changed.
    It is currently not possible to check, if that permission was changed from default 0 to custom 0 on a channel create.
  1. [Rejected] [Already Possible] Channel permissions "create subchannel" and "spacer"
    By Taktik in forum Suggestions and Feedback
    Last Post: March 12th, 2013, 10:21 AM
  2. [Resolved] Auto Setting Channel 'Needed Delete Power'
    By MarkA2049 in forum Permission System
    Last Post: March 25th, 2012, 11:15 AM
  3. [Resolved] Change Channel "Delete Power"
    By TCG-Smith in forum Permission System
    Last Post: February 6th, 2012, 01:55 PM
  4. Bug(?): "needed channel delete power" is not default 0
    By Animor in forum Permission System
    Last Post: July 27th, 2011, 08:15 AM
  5. Replies: 18
    Last Post: August 17th, 2010, 11:46 AM
