Page 2 of 5 FirstFirst 1234 ... LastLast
Results 16 to 30 of 75
  1. #16
    February 2015
    10
    Hi TeamSpeak,
    Is it possible to get a list of my current Bookmarks and use a bookmark to switch server with ClientQuery?
    If it is possible, which command it?
    I probably got tunnel vision trying to find it
  2. #17
    18,153
    It's not possible.
    There is no connect / disconnect command at all.
  3. #18
    February 2015
    10
    It's not possible.
    Thank you.
    I will stop looking now
    Any chance something may be added in the future?
  4. #19
    December 2014
    Event Documentation
    I'm missing the documentation of the Clientnotifyregister Events, or more specifically the parameters of those events.
    Since there are 29 events, having to test each one with different permissions, invokers and so on is very time intensive.
    It would be nice to have a documentation of those including their datatypes (especially with numbers if they are singed and their range/bytes)
  5. #20
    April 2016
    7
    missing info about mute / unmute
    Hi, from few days I cant receive any information when I call mute or unmute Clients directly on TeamSpeak Client. Of course functionality works, but when we connect to TS by telnet and make command: clientnotifyregister schandlerid=1 event=any, then there is information about my update like away, speaker mute...and when someone is updates himself but not when we mute on TS application.
    I made everything like install uninstall or uncheck plugin but it not help.
    I use TS3 3.0.19.1 and QT 5.5.1
  6. #21
    October 2015
    Question Muting yourself
    Hey there,
    great plugin, but I can't figure out how to mute myself not anyone else.
    I also tried using clientmute with my client id reported by whoami & even though I got success message, I'm not muted at all.
    Any idea ?
  7. #22
    May 2016
    Idar-Oberstein
    163
    try clientupdate
    client_input_muted: 0 or 1, mutes or unmutes microphone
    client_output_muted: 0 or 1, mutes or unmutes speakers/headphones
  8. #23
    October 2015
    Thumbs up
    Quote Originally Posted by thorwe View Post
    try clientupdate
    Thank you very much for the heads up!
    Just tested it, simply awesome.
  9. #24
    February 2015
    10
    Hi TeamSpeak.
    Just updated TeamSpeak to 3.13
    My TS Remote program won't connect to ClientQuery anymore.
    Error:
    No connection could be made because the target machine actively refused it 127.0.0.1:25639
    Using VB.net
    TcpClient.Connect("localhost", 25639)
    Is this my fault do I need to change something since the new update?
    It worked ok before the update.
  10. #25
    4,351
    Read changelog. ClientQuery changed significantly.
  11. #26
    February 2015
    10
    Don't suppose you could give me a link to where change logs are
    I probably just can't see the wood for the trees.
  12. #27
    4,351
    In the client.
  13. #28
    6,079
    Might want to have a look for yourself ;-)
    The changelog kinda missed to mention any specifics as to what changed. It is however mentioned in the announcement.
    Basically you will need to authenticate before being able to send any commands (exception being help).
  14. #29
    February 2015
    10
    thanks
    silly me trying to find a copy on TeamSpeaks web site.
    Got it sorted.
  15. #30
    4,351
    Someone quoted something in another thread which I thought was from the changelog.
  1. [Not possible] ClientQuery plugin Source?
    By FaltyR in forum Client Plugins / Lua Scripts
    Last Post: August 18th, 2018, 03:05 PM
  2. Trouble with Clientquery Plugin - Disconnect from server
    By DayDreamer87 in forum Client Plugins / Lua Scripts
    Last Post: August 22nd, 2014, 10:05 PM
  3. Problem with Clientquery Plugin / clientlist special symbols
    Last Post: December 14th, 2013, 09:55 PM
  4. How to connect to server via clientquery plugin
    By rubinau in forum Client Plugins / Lua Scripts
    Last Post: October 2nd, 2012, 05:40 AM
  5. ClientQuery plugin
    By florian_fr40 in forum Client Plugins / Lua Scripts
    Last Post: October 14th, 2010, 05:33 PM
