Page 5 of 5 FirstFirst ... 345
Results 61 to 75 of 75
  1. #61
    17,947
    I guess you timed out.
    This happens when ~10 minutes no command was send to the Server/Client Query interface.
  2. #62
    October 2015
    26
    So, will I not get timed out if I put a help command every few minutes? Or am I understanding this wrong?
    Edit:
    Yes, it did work. Thank you so much. Also, will there be any other commands added in the future?
  3. #63
    17,947
    Quote Originally Posted by dzinks2009 View Post
    Not that I'm aware of
  4. #64
    4,335
    I send 0x0A every 5 minutes in my software to not time out.
    If the officially documented commands are not enough for you, you may want to use undocumented commands like these:
    channelsubscribe
    channelunsubscribe
    channelsubscribeall
    channelunsubscribeall
    We update it, when needed.
    *cough* file transfers *cough*
  5. #65
    October 2015
    26
    Hmm, thanks.
    Also, sometimes when I get the notification and I call whoAmI it tells me the wrong information in whoAmI.(Doesn't return anything tbh)
  6. #66
    4,335
    I cannot confirm that behaviour (at least not until you call another undocumented command, which I don't think you are doing).
  7. #67
    October 2015
    26
    I register for "any"
  8. #68
    December 2015
    7
    There were no examples folder shipped with my installation, is there a github link somewhere where I can get a hang of how it works?
  9. #69
    4,335
    Use help.
    fabljsfbalkfbaabsvklfa
  10. #70
    April 2019
    libclientquery_plugin_mac.dylib not signed
    Hello, I would like to let you know that when I've updated TeamSpeak to 3.2.5 on my macOS yesterday, LittleSnitch warned me that this new update has "modified" the program and while attempting to connect to clientapi.myteamspeak.com, it loaded an unsigned library from the path /Users/smjert/Library/Application Support/Teamspeak 3/plugins/libclientquery_plugin_mac.dylib.
    I've checked that library with codesign and effectively there's no signature, so it seems you've shipped part of the application unsigned (everything else that is in the Applications .app folder seems fine).
    Last edited by dante696; April 26th, 2019 at 07:38 AM. Reason: moved out of client release thread. this plugin has nothing to do with the release
  11. #71
    17,947
    I moved that out of the client 3.2.5 release thread. The plugin itself has nothing to do with the client release.
    You should have that error before the update because the last time we did update that plugin was in 2017.
    Unfortunately i can not reproduce that warning. Downloaded the latest LittleSnitch version and tried the plugin but no warning appeared.
  12. #72
    April 2019
    Thanks for the update and the test.
    Just to understand though, is it normal that the plugin doesn't have a signature (I've checked with codesign too)?
  13. #73
    December 2018
  14. #74
    17,947
    Yes. This should not happen.
    I will forward that issue.
  15. #75
    February 2017
    Kepler-186f
    58
    would it be possible to remove the currentServerConnectionChanged event from the console?
    Name:  Anmerkung 2019-06-30 175231.png
  1. [Not possible] ClientQuery plugin Source?
    By FaltyR in forum Client Plugins / Lua Scripts
    Last Post: August 18th, 2018, 03:05 PM
  2. Trouble with Clientquery Plugin - Disconnect from server
    By DayDreamer87 in forum Client Plugins / Lua Scripts
    Last Post: August 22nd, 2014, 10:05 PM
  3. Problem with Clientquery Plugin / clientlist special symbols
    Last Post: December 14th, 2013, 09:55 PM
  4. How to connect to server via clientquery plugin
    By rubinau in forum Client Plugins / Lua Scripts
    Last Post: October 2nd, 2012, 05:40 AM
  5. ClientQuery plugin
    By florian_fr40 in forum Client Plugins / Lua Scripts
    Last Post: October 14th, 2010, 05:33 PM
