Results 31 to 45 of 49
  1. #31
    May 2007
    Eastern NC
    1,799
    Please double check the how to's:
    - You must use WLAN
    - Make sure your phone is in the same LAN and has access to the Computer (Could be tested with ping or AIR Droid etc.)
    - Enable the ClientQuery plugin and check "Open telnet for everyone"
    - check client log, when you enable "Open telnet for everyone"
    Should show -----> 26.06.2014 13:49:22 Query Info listening on 127.0.0.1:25639
    - Try to disbale your firewall for testing
    - Last thing: Do not think that this app if for talking. It's Just a Remote App.
    Something else to add is to make sure the router does not have AP isolation enabled.
  2. #32
    September 2014
    May I request a sort setting? I want to use this in place of an overlay, and since there are 50+ people in my channel I want to see the most recently talking at the top.
  3. #33
    January 2016
    Quote Originally Posted by Moony22 View Post
    as my windows 10 hates using the overlay now +1 to this option (also bump)
  4. #34
    January 2017
    Using android
    I uploaded the app for my phone to chat. its asking me for IP of my computer where TeamSpeak is running. Where would I get that info. Im new to this
    Last edited by dante696; January 6th, 2017 at 10:38 AM. Reason: merged, manual explains how to get the IP
  5. #35
    July 2014
    26
    TS3 Remote no longer works with the TS3 update due to the ClientQuery change. Is a fix in the works? Thank you
  6. #36
    18,241
    Quote Originally Posted by Fakum View Post
    Yes a fix will come. That was already said as reply in your other posts.
  7. #37
    July 2014
    26
    Yes, you said
    "The TS3 Remote application does use telnet to communicate with the plugin and you have to wait for an update (i don't know when an update will be available for the application)."
    So would this not be the appropriate thread to discuss TS3 Remote update specifically?
  8. #38
    August 2013
    540
  9. #39
    July 2014
    26
    Thanks, that looks like alot of stuff I dont need or want, but will try it if TS3 Remote is not updated in the near future, thanks.
  10. #40
    July 2014
    26
    I would like to follow up with the status of this fix please. Thank you kindly,,,,
    by the way, I did try to install that app noted above just to remedy my situation, but it would not play nice, I could not connect to the server I wanted, kept getting errors, and I did watch the youtube tutorial and confirmed the settings in TS,,,, just more dumb luck!
  11. #41
    6,079
    An update will come in the future but not this month.
  12. #42
    July 2014
    26
    Thanks for the response. Any chance you can define "Future"? 2017 2027?, in the meanwhile,can you recommend anything else in the mean time? I tried every app that came up available on my Android phone, all miserable failure for me. Thanks,
  13. #43
    6,079
    2017 should be doable, no promises though (as usual) ;-)
  14. #44
    July 2014
    26
    I appreciate the feedback, thank you sir.
  15. #45
    July 2014
    26
    Just checking in to minimize it falling thru the cracks
  1. (Outdated) TS3 Remote (Android App) API-Key / Interface-Menübutton
    By DaDevilfreak in forum Tools / Web Based
    Last Post: March 4th, 2019, 07:44 PM
  2. [Not possible] Cannot use TS3 remote on my Galaxy S5 Android.
    By Johnnly Leviathon in forum Android
    Last Post: July 16th, 2015, 08:43 AM
  3. Use Android tablet as wireles mic through TS3 Remote app?
    By WAFFLE OF WAR in forum General Questions
    Last Post: July 6th, 2013, 04:18 PM
  4. Replies: 1
    Last Post: August 6th, 2012, 06:10 PM
