Results 1 to 6 of 6
    USA
    85
    Solved (not possible) Sound Scripts - Any way to turn off per channel?
    i want to turn off all sound scripts on one channel; is there any way to do this?
    the channel is for when you are busy doing something else and you dont/cant talk. i made an 'afk' channel, gave it needed talk power of 200 so no one can talk, but when in it you can still hear the channel joined/disconnected/etc sound scripts.
    If anyone knows how to turn these off on a channel basis or some other method to totally mute all sounds on one channel (without having to mute the speakers), let me know.
    thanks,
    mark
    November 2010
    Poland
    55
    USA
    85
    Quote Originally Posted by polski View Post
    thanks for the response
    but thats not exactly what i want; that tutorial shows you how to change the sound level per server
    i want to do it per channel
    18,261
    This is not possible. You can change it for different bookmarks, but not for channels.
    October 2011
    Just verifying this is still not possible. There is no way to set up a "need quiet but not afk" channel for our guild? Like there's no way to turn off all sound/notifications in a channel?
    18,261
    Exactly there is no way to set a sound script for each channel and this won't be changed, but there is a way to switch the soundpack to "deactivated" per hotkey.
    Just open Settings > Options > Hotkeys > Add (next to Remove) > Show Advanced Actions > Go to Sounds
    now you can deactivate the sounds or switch to another instaleld soundpack.
  1. Help! Can't turn up my sound more than -10 decibals!
    By hannaleanne in forum Client Support
    Last Post: January 28th, 2013, 09:31 AM
  2. Sound Scripts
    By Lorenya in forum General Questions
    Last Post: June 23rd, 2011, 01:22 AM
  3. adding sound scripts if settings show not available...
    By dmp2005 in forum Client Support
    Last Post: June 14th, 2011, 08:54 AM
