Page 11 of 13 FirstFirst ... 910111213 LastLast
Results 151 to 165 of 191
  1. #151
    July 2015
    Proplem
    Hi Evreone
    Ihave abug or something like that when i open the TS
    its sayes "error spawning server connecting handler"
    pls help me
    iam useing ESET antivirus
    Thanks
  2. #152
    August 2015
    Client Crash: Error Spawning Server Connecting Handler
Size:  12.1 KB This is a message I get whenever I try to open TS3, I have tried System recovery and and uninstalling and reinstalling the program. No idea! Help!
  3. #153
    August 2015
    "Teamspeak Fails Because it cannot find any port"
    So after a nasty malware attack, got all of the crud scrubbed finally and went to startup TS3 client and it will not run anymore. I get an error "teamspeak fails to start because it cannot find any port". TS3 client was working fine before this, now this is all it does. I have tried looking for answers and trying them, disabled my firewalls, tried a Port Forwarding guide that was supposed to unlock the ports needed on my router, but nothing works, same error over and over. I take it from research that it is something with one of the three ports, 9987, 10011, or 30033 but I have never messed with router before and I am still trying to grasp how the malware issue could have broken my TS client. I can't seem to get the search function to work on this forum for some reason. Looking for any help that anyone can give, especially TS company admins.
    Thanks in advance....
  4. #154
    August 2015
    Hey all! im having a huge amount of trouble on teamspeak, when i try to open teamspeak 3 it says "Teamspeak Fails Because it cannot find any port" i checked Knowledge Base and i know its not my firewall or Anti-Virus, the other ones, "No network card was found to open a connection," and "A P2P (or other) software is using the required ports." Im not too sure about, i dont know what they mean, if anyone else has solved this problem, PLEASE help, i have friends that use this only and i want to talk to them!
  5. #155
    6,079
    All of your ephemeral ports are in use, as such the client cannot establish a connection to anything (as the operating system has no ports available to give to the client) and terminates.
    Make sure to check your configured ephemeral port range and that there are not massive amounts of connections from your system.
  6. #156
    August 2015
    "Teamspeak fails to start because it cannot find any port" error
    I get this error every time i start ts3. I dont have an antivirus and i have internet connection and I forwarded 3 different ports that i found online which were supposedly the three ports ts3 uses. I just had a large virus on my computer but i got rid of most of it and not my ts3 does not work. Please help!
  7. #157
    August 2015
    I don't know how to check my ephemeral port, where i have to go for that please?
  8. #158
    August 2015
    Same error
    Im also have the same issue, I have checked my ephemeral ports in powershell.
    The max % of port usage is 0.3% in the past 5mins
    41 ports out of 16384 is clearly not the issue.
    Any other reason why Teamspeak is refusing to open due to this *cannot find any port*
  9. #159
    August 2015
    Same issue and its not the Ephemeral port ports as im using 0.3% of them out of 16384
    Anything else it could be?
  10. #160
    August 2015
    "TeamSpeak fails to start because it cannot find any port"
    So I keep getting this message when trying to start TS3. I had some virus thing but pretty much got rid of it. Before and during the virus-thing it worked perfectly fine but now I can't seem to run it or any other games I have installed in Steam. Tried re-installing, cleaned my pc, restarted, checked for updates but nothing. I really need help!
  11. #161
    August 2015
    TeamSpeak fails to start because it can not find any port
    After a virus that I cleaned up my TeamSpeak will not open and it pops up with the message "TeamSpeak fails to start because it can not find any port" and the link that it gives you in the message did not help. I saw one of the staff members talk about changing your ephemeral port but I have no idea what that means or how to get to it. Please help.
  12. #162
    December 2014
    I had the same problem!
    Hi, i had the same problem! My fix was installing a program called "adwcleaner"! No problem
  13. #163
    August 2015
    Hello guys. I updated window 7 to window 10, but after some problems i decided to restore my old system. After the restore (so now i'm in window 7) i have this error when i try to open Ts3 client "TeamSpeak fails to start because it cannot find any port".
    I tried to uninstall ts3, i tried to disable Antivirus and firewall and i checked with netstat if all ports are busy but all seems correct.
    I'm running ts3 client version 3.0.17
    Thank you for the help!
    Cheers
  14. #164
    August 2015
    TeamSpeak fails to start as it cannot find any ports!!!
    I got this problem yesterday and after searching it up it appears that everyone who has got (and reported) this has just scrubbed malware off their PC, same case with me. I see a pattern emerging, i assume this is definitely something to do with either the malware or anti-malware though as far as i can tell TS isn't blocked on any of my anti-malware suites as of late i haven't found any solutions as it appears to be a fairly new problem. just want to stress this issue to hopefully get it fixed sooner here is the original (unsolved) thread. http://forum.teamspeak.com/showthrea...-any-port-quot
    Thanks in advance.
  15. #165
    August 2015
    Luxemburg
    Maybe Winsock Issue
    Hello !
    Got the same problem, and i resolved it that way :
    Start menu > All programs > Accessories > right-click on "Command Prompt" and "Run as Administrator".
    Type > "netsh winsock reset" in the Command prompt shell, and press the Enter key.
    Type > "netsh int ipv4 reset" in the Command prompt shell, and press the Enter key.
    PS : If you use ipv6 : Type > "netsh int ipv6 reset" in the command prompt shell, and press the Enter key.
    Restart your computer.. TS should work.. if it doesn't... well... good luck
  1. Replies: 2
    Last Post: July 31st, 2011, 12:27 PM
