Page 12 of 13 FirstFirst ... 210111213 LastLast
Results 166 to 180 of 191
  1. #166
    August 2015
    Teamspeak fails to start because it cannot find port
    i keep getting this error mainly after i got a virus on my pc and tthen removed it with malware antivirus i need help because teamspeak wont start now
    Last edited by dante696; August 22nd, 2015 at 12:26 PM. Reason: merged / then your system still is infected!
  2. #167
    August 2015
    error when trying to run ts3
    I get the following message 'Error spawning server connecting handler' can anyone help please
    Regards
    Bob
    Last edited by dante696; August 24th, 2015 at 08:42 PM. Reason: update your clien to 3.0.17! check what we answered already.
  3. #168
    September 2015
    Un-able to launch
    I downloaded teamspeak and everything went okay, but when I try to actually launch it I get. "A critical error occured, the application will be terminated. Please notify us in our forums about the error" The reason was "Error Spawning Server Connection Handler". I dont know how to fix this. Can anybody help?
  4. #169
    18,151
    Step 1: update your client to 3.0.17
    Step 2: http://forum.teamspeak.com/showthrea...516#post293516
  5. #170
    September 2015
    TeamSpeak fails to start becouse it can't find any ports.
    Hello!
    I just bought new PC with Win10 a few days ago... when i installed teamspeak this error occured:
    "TeamSpeak fails to start becouse it can't find any ports."
    I found i have some viruses / malwares, i deleted them but it didn't help. I tried turning off WinDefender, antivirus, antimalware, but it still don't resolve the problem. Do you know what to do?
  6. #171
    September 2015
    This problem occours, when your operation system does not offer any port for the client.
    We use Ephemeral ports ranges for the client (http://en.wikipedia.org/wiki/Ephemeral_port) and you will get this error from the client, when we can not open any port for the client.
    Possible reasons are:
    - Firewall/Antivirus tools block the client
    - The network card wasn't found or could not opened
    - A P2P program blocks all ports
    - You computer could be infected with a trojan or botnet
    Please check all these points. It's a local problem on your computer.
    The TeamSpeak developers can not fix this.
    Client 3.0.17 will show another message with an URL to the knowledge base
    I'm having this problem and I seen this in the knowledge base but i dont know how to go about fixing the issue. Ive tried checking to see if any of these were the issue but it still wont work.
  7. #172
    September 2015
    tS3 finds no ports to use
    Ive browsed the web for multiple hours now, and the point has come where I dont know what to do.
    Iīve tried everything. Restarting my pc, reinstalling teamspeak, disabling all firewalls, and I even checked if the port is used( itīs not). I even found some logs which could be helpful to any of you guys trying to help me.
    http://pastebin.com/Zh2qi9nf
    Thx for helping me
    Greets x
  8. #173
    August 2013
    540
    2015-09-23 13:23:35.297482|ERROR |Query | |bind failed on 127.0.0.1:25639
    Free used port 25639 or disable "Client Query Plugin".
  9. #174
    September 2015
    How can I disable the Client Query Plugin?
  10. #175
    September 2015
    Just checked what parts are in use and the port you listed there is not in use.
    So the last thing what could me is that Client Query Plugin. But I dont know how to disable it.
    I deleted it out of both plugin folders, but TS3 still doesnt work.
  11. #176
    18,151
    Merged!
    You both mixed up wrong topic!
    Ts3 client can not be found is another issue than Client Query Plugin
  12. #177
    October 2015
    I can't open Teamspeak 3 anymore HELP
    Overnight I can't just open TS3, it's write <<Teamspeak fails to start because it cannot find any port>> But it's not one of the 3 reasons.
  13. #178
    October 2015
    TeamSpeak fails to start because it cannot find any port
    Hey, i keep getting these messages, i tried to download adwcleaner, i tried to delete all the antiviruses i have, or even disable the firewall, but nothing works, i just keep getting that error, please help, i'm managing a server.
  14. #179
    October 2015
    Teamspeak 3 problem. Teamspeak fails to start because it cannot find any port. Help!!
    I am running on windows 10
    My router is a Linksys EA3500
    Okay so yesterday I decided to install the trial of avg antivirus? After installing I decided I did not like it and pretty much uninstalled it after 5 minutes of use. After uninstalling I found that I could not connect to servers of any kind, whether it was Dota 2, Minecraft, or whatever. Yet I am still able to surf the web and download stuff. I have tried turning off my firewall, which didn't work. Then I reset my router and specifically forwarded the ports that TeamSpeak uses.
    When I tried to open Teamspeak I got an error message saying :"TeamSpeak fails to start because it cannot find any port. Please see our knowledge base for further details."
    The error I get from Dota 2 says: "Failed to gather ping information. Please verify that your internet connection is working and that the Dota 2 servers are online."
    Please Help!!
  15. #180
    November 2015
    I was using ts3 for a long time and now I started getting "TeamSpeak fails to start because it cannot find any port" randomly.
    https://gyazo.com/48b966472549fa5d9153d461ca673f44
    What should I do?
  1. Replies: 2
    Last Post: July 31st, 2011, 12:27 PM
