You might want to consider using the search function or read this thread: http://forum.teamspeak.com/showthrea...cting-handler/
In teamspeak 3, when i try and launch I get the following message:
"A critical error occurred, the application will be terminated. Please notify us about the error in our support forum.
Error spawning server connecting handler"
I deleted teamspeak and re-ran the installation, in both modes (Installing the files in one user, in all, and in the installation folder as well as in the user's personal files). TS was running less than 24 hours earlier, and I have not installed any new programs, deleted any old ones, done any sick dumps or reformatting, nothing of the sort.
Any help that can be provided would be wonderful! Thank you!
*Edit* Also, I do not have overwolf installed, or any extra plugins. The only modification I have made to TS is I put a new skin on, but that was literally months ago so I have a hard time believing that the skin had anything to do with it
it will not work it say cont ppl here about it thank i can log in ts3 at all
I get this error whenever I try to open Teamspeak, I restarted my computer and it still happened.
Every time i go to open TS3 i get Error spawning server connecting handler and it terminates TS and i can not get to it
Hi guys ..
When you open the program this message appears
" Error spawning server connecting handler "
What should I do?![]()
Check this thread -> http://forum.teamspeak.com/showthrea...ecting-handler
i check all post but still not find any solution
Last time I tried using TS3 it failed to load and the message 'Error spawning server connecting handler' popped up.
I have tried deleting and reinstalling the file but the error message persists.
I'm not overtly tech savvy so use small words![]()
I cant seem to fix this no matter what i try, any help would be greatly thanked...
yea im getting the same error
so it appears a lot of us are having the same issue but none of us know how to fix it.
does anyone actually know how to fix the problem? like I know the TS team cant but is there something the user can do to allow the connecting handle to spawn?
How to fix?
This thread, posts #11 and #43:
