Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 110
  1. #46
    August 2011
    I don't hear any team speak sound
    I check the last update and i can't hear any ts sound. The cue ball blue lights but i don't hear any person.
    Ps: The other people can hear me!
    Ciao
  2. #47
    August 2011
    I have the same exact problem, everybody can hear me, but I can't hear anything, including the teamspeak sound messages...
  3. #48
    August 2011
    Quote Originally Posted by nwerensteijn View Post
    The next release should have 1 channel sound (like voices and some notifications) coming from front left+right channel in surround sound setups.
    When can we expect that update since I really get into trouble for not hearing my teammates via whisper-lists?
  4. #49
    August 2011
    Yes, this is also the exact same problem I have. And I've tried many things already. Like reinstalling, and updating the computer updates for any drivers, that may have needed it. However if you check the warnings these 2 always show for me:
    8/11/2011 5:04:05 PM Direct Sound Warning RenderDeviceContext::int_processData Loop proc time: 47 msecs
    8/11/2011 5:04:05 PM Direct Sound Warning RenderDeviceContext::int_processData outerLoop proc (3) time: 107 msecs
    the last part is different, because it's with time, but everytime. I've always used direct sound.
  5. #50
    April 2010
    Hungary
    I have this same error.
    TS3 I hear every sound, but I can not hear anyone. Other friends, this is the same error. Quick fix please
  6. #51
    August 2011
    After the last updated make me this error.
  7. #52
    August 2011
    I have same problem ever since i updated, I cannot hear any sound.....However most of my corporation members have no problem with this issue...please fix very quickly or put a previous version before update back up as one cannot perform in fleet without communication.
  8. #53
    August 2011
    Registered just say that I also have this problem with the latest update though didn't have it any previous ones. That temporary solution did fix it though the sound quality when people hear me is bad. Wish I didnt update....
  9. #54
    August 2011
    i have the same problem pls help me
  10. #55
    August 2011
    The weird thing is that on Window7 32 Bit it does work, but in Window Xp 32 bit it doesnt work the playback sound. It like doesnt pick up the sound device thats configured although I tried direct sound and the best mode one too. I think its a os problem idk just guessing.
  11. #56
    August 2011
    What can i do?
  12. #57
    August 2011
    Angry
    Quote Originally Posted by tHAWK View Post
    I know how to fix it . Go to my control panel, then to sounds and audio devices. click on volume tab at the top. then at the bottom
    where it says speaker settings click on advanced change the speaker settings to anything in the list then click apply. test your ts to see if it works. if it does then go ahead and change your setting back the way you want and click apply. everything will work then. I hope this helps.
    This did not change a thing... Still no sound in head phones on TS.......
  13. #58
    August 2011
    Quote Originally Posted by Edelhonk View Post
    Seems there is a massive bug with the latest TS client and 5.1 systems.
    Have the same here. Windows XP SP3 system. Everything was fine before the patch. After the patch i couldnt here nobody in the TS but everyone could here me in the channel and i couldnt even here the test sound in TS3 output options settings...every other sound from games or vids as example was played normal.
    After i set my speakers from 5.1 to a normal stereo system and restarted TS it worked fine again.
    But now i have to set my system allways to stereo speaker before i start the TS-client, cause otherwise i have the no sound bug again, and after the TS3 client is running i can set the system back to 5.1 speakers/headset.
    I hope they will fix this with a hotfix very fast.
    I have windows XP this works .. the key is to shut down TS before the change and then restart,, what a pain in the ASS !!!!!!
  14. #59
    August 2011
    Exclamation Got exact the same problem...
    Since i've done the update today, i don't have any sounds in ts3.
    Other people can hear me, but me not.
    Here's a log file of me .... maybe it will help somehow
    2011-08-12 22:11:19.747070|INFO | | | Logging started, clientlib version: 3.0.0 [Build: 14954]
    2011-08-12 22:11:19.789062|DEBUG |Direct Sound | | setting timer resolution to 1ms
    2011-08-12 22:11:19.878906|INFO | | | Registering plugin command id: {9d254cbc-a293-4d8b-9808-a58ce9f47316} appscanner_plugin
    2011-08-12 22:11:19.892578|INFO |Query | | listening on 127.0.0.1:25639
    2011-08-12 22:11:19.892578|INFO | | | Registering plugin command id: {d219c7cb-8821-4d4b-8a90-d9d8943f53f6} clientquery_plugin
    2011-08-12 22:11:20.393554|INFO |ClientUI | | TeamSpeak 3 client version: 3.0.0 [Build: 14954]
    2011-08-12 22:11:20.393554|INFO |ClientUI | | Qt version: 4.7.2
    2011-08-12 22:11:20.393554|INFO |ClientUI | | Using configuration location: C:/Users/Greaven/AppData/Roaming/TS3Client/ts3clientui_qt.conf
    2011-08-12 22:11:20.407226|INFO |Input | | Input device name: Maus
    2011-08-12 22:11:20.409179|INFO |Input | | Input device name: Tastatur
    2011-08-12 22:11:20.427734|INFO |Input | | Input device name: Logitech G13 Joystick
    2011-08-12 22:11:20.828125|INFO |ClientUI | | Last update check was: Fr 12. Aug 13:14:08 2011
    2011-08-12 22:11:22.660156|DEBUG |Windows Audio Session| | WAS:penDevice-enter
    2011-08-12 22:11:22.690429|DEBUG |Windows Audio Session| | WAS Buffer size: 1440
    2011-08-12 22:11:22.690429|DEBUG |Windows Audio Session| | WAS:penDevice-leave
    2011-08-12 22:11:22.690429|DEBUG |Windows Audio Session| | WAS::startDevice-enter
    2011-08-12 22:11:22.691406|DEBUG |Windows Audio Session| | WAS::startDevice-leave
    2011-08-12 22:11:22.691406|DEBUG |Windows Audio Session| | WAS:penDevice-enter
    2011-08-12 22:11:22.699218|DEBUG |Windows Audio Session| | WAS Buffer size: 960
    2011-08-12 22:11:22.699218|DEBUG |Windows Audio Session| | WAS:penDevice-leave
    2011-08-12 22:11:22.699218|INFO |PreProSpeex | 1| Speex version: speex-1.2beta3
    2011-08-12 22:11:22.700195|DEBUG |Windows Audio Session| | WAS::startDevice-enter
    2011-08-12 22:11:22.700195|DEBUG |Windows Audio Session| | WAS::startDevice-leave
    2011-08-12 22:12:15.319335|DEBUG |Windows Audio Session| | WAS::associateAECDevice-enter
    2011-08-12 22:12:15.319335|DEBUG |Windows Audio Session| | WAS::associateAECDevice-leave
    2011-08-12 22:14:05.198242|INFO | | | Checking for updates...
    2011-08-12 22:14:05.479492|INFO | | | Update check, my version: 14954, latest version: 14954
    2011-08-12 22:15:26.253906|INFO |PlaySoundSet | | Invalid playbackDevice in Config File, (profile, playbackDevice) = (Standard, Lautsprecher (Creative SB X-Fi))
    2011-08-12 22:15:27.289062|DEBUG |Windows Audio Session| | WAS::associateAECDevice-enter
    2011-08-12 22:15:27.289062|DEBUG |Windows Audio Session| | WAS::associateAECDevice-leave
    2011-08-12 22:15:27.289062|DEBUG |Windows Audio Session| | WAS::stopDevice-enter
    2011-08-12 22:15:27.289062|DEBUG |Windows Audio Session| | WAS::stopDevice-leave
    2011-08-12 22:15:27.289062|DEBUG |Windows Audio Session| | WAS::closeDevice-enter
    2011-08-12 22:15:27.289062|DEBUG |Windows Audio Session| | WAS::closeDevice-leave
  15. #60
    August 2011
    Have same problem with this shitie update
  1. Replies: 0
    Last Post: September 26th, 2015, 11:45 AM
  2. No playback sound
    By rmcconn in forum Windows
    Last Post: June 9th, 2015, 10:20 AM
  3. Replies: 0
    Last Post: March 1st, 2014, 03:43 AM
  4. playback
    By Naiteki in forum Windows
    Last Post: April 29th, 2010, 01:14 PM
