Page 3 of 11 FirstFirst 12345 ... LastLast
Results 31 to 45 of 163
  1. #31
    2,029
    Thing with lots of the Origin Games seems to be that you cannot launch them directly, only through Origin.
  2. #32
    June 2012
    Push to Talk does not work in Admin programs in Win 7
    Hi guys,
    I noticed not long ago that my TS3's push to talk does not work in some games/programs, and especially installers. I turned on mic activation clicks so I could test this.
    I have found that in programs with the little shield ("Run as Admin", or programs that otherwise alter the files like downloaders, installers etc), my push to talk will simply not activate.
    I have tried running in every variation of compatibility mode, and running TS3 as an admin just makes it so that I can't talk at all!
    I have searched for this problem but every suggestion is to run TS3 as admin, which just makes the problem worse and seems to be exactly the opposite of what everyone else is having.
    Turning TS3 to voice activation helps in some games/programs, but not others.
    I am running Windows 7 with a Sound Plaster X-fi sound card with analogue head phones. Example programs that have this problem: FRAPS, Battleforge, almost every InstallShield wizard, PlanetSide, Railworks 3. I have disabled "Run as Admin" in these programs but nevertheless the little shield on the shortcut - and the problem - persists. They still ask me for permission to modify files.
    Thanks for any help.
    ----------------merged--------------
    I have had a brainwave after a few hours of troubleshooting and I think I have the problem pinned down.
    Basically, I have a mouse with buttons on it. Those buttons link to keyboard keys that I do not normally use like ', :, [ and ]. I use Logitech software to program the keys, and I use one of these keys for my PTT so I can easily use comms in shooters etc without taking my hands off the controls.
    Anyway, apparently when I turned admin mode on for TS3, I guess the Logitech software had some sort of conflict and wouldn't allow the mouse to push the PTT key in the program. I assume this is also the thing that was preventing me from using PTT in admin-run programs like PlanetSide. By setting the Logitech software to admin mode it seems to have solved the issue.
    This thread got merged and moved. There is nothing else we can do
  3. #33
    July 2012
    teamspeak 3 ptt problem
    hello forgive me but do not speak English and I'm using the google translator, use Teamspeak 3 to speak while I play but I have a problem, always use this program well and never had this problem, my problem is that I set it up to use the push-to-talk test and check it works accept and apply the options, but when talking does not work, I see the options and are applied, the other users on my server without any problems using the push-to-talk
    Thread was merged
  4. #34
    18,271
    I do not reply in your double post.
    So if this not the problem, then you maybe try another hotkey mode
    under Settings > Options > Hotkeys
  5. #35
    August 2012
    Cant use teamspeak in game
    It seems I can use teamspeak while in the teamspeak site. When I run my game I cant use the teamspeak UNLESS I have the window up in game. When I minimize the window in game, the teamspeak no longer works in game. I am using windows 7 on my comp. Any ideas? thanks.
    Thread was merged
  6. #36
    July 2006
    1,600
    Try running teamspeak as administrator.
  7. #37
    Problem with push-to-talk on windows 7 64bits
    I use Teamspeak 3.0.8.1, and my buttons don't work when I'm playing (on Aion or League of legends for example).
    I have a 64bits version of Windows 7, I downloaded 64bit version of TS3 and I don't understand. I had this problem with my old computer, but only for League of Legends, it worked very well on Aion. I have to use the push-to-talk but with this problem, I can't activate it. My drivers and my directx are all right i think, i can find it if needed.
    Thanks and sorry for any english error, I don't speak this language very well.
  8. #38
    18,271
    This happens, when a game or an game launcher does start as an admin.
    Leauge of Legends does have 2 ways to start the game and one way is without admin.
    lol.launcher.admin.exe
    lol.launcher.exe
    Thread was merged.
  9. #39
    October 2012
    Question push to talk doesn't work
    hey guys,
    my PTT (push to talk) is not working when i start up for example world of tanks. when i open my teamspeak it works, but when i open world of tanks it doesn't. voice activation detection does works. can someone please help me?
    P.S: i tried so set my hotkeys on default, mouse & keyboard only and direct input. but nothing of these options worked
    This thread was moved
  10. #40
    February 2012
    France
    69
    Have you try to verify if world of thank disable your teamspeak microphone ?
  11. #41
    6,080
    Make sure the game is not running in admin mode, otherwise windows won't relay the keys to TeamSpeak.
    If the game is using a launcher try starting the main executable directly instead of through the launcher. Many launchers try to run a game with admin permissions.
  12. #42
    October 2012
    TeamSpeak does not work in game
    updated TS3 today and I have a problem, I can not speak in the game WOT World of Tanks,
    get out of the game, I can say, as in the game I did not hear anything! client game.
    Russian part removed, forum is English only!
  13. #43
    6,080
    If you are using Push to Talk you should make sure that the game is not running in Admin Mode, otherwise TeamSpeak cannot detect if any keys are being pressed as windows doesn't make the information available.
    Voice Activation should always work.
    If the game is not running in admin mode and you are sure about that try another hotkey detection method in settings -> options -> hotkeys. The drop down above the apply button.
  14. #44
    October 2012
    got the same preblem with to pcs
    have had the same probs with the update from 3.0.8.1 --> 3.0.9 on too pcs...
    Solution, downgrade to 3.0.8.1 and wait till they fix it...
    system windows 7 64bit
  15. #45
    October 2012
    Same issue here with Wot
    Same issue. I'll Dgrade...
  1. Teamspeak doesn't work with my game
    By striker9915 in forum Windows
    Last Post: July 26th, 2013, 06:39 PM
  2. Hotkeys doesn't work in CounterStrike:Source STEAM
    By naonao in forum Bug Reports [EN/DE]
    Last Post: May 18th, 2012, 07:26 PM
  3. Hotkeys in in background or while in game doesn't work
    By Look_Up in forum Bug Reports [EN/DE]
    Last Post: August 12th, 2011, 12:59 AM
  4. TS doesn't work in background
    By Telman in forum macOS
    Last Post: September 25th, 2010, 01:56 AM
