Page 5 of 11 FirstFirst ... 34567 ... LastLast
Results 61 to 75 of 163
  1. #61
    April 2012
    My clan in WoT has found that if you open TS3 as administrator then the Push to Talk feature works. TS need to look at this and determine a cause and fix.
  2. #62
    October 2012
    not working since update
    Hi, i updated yesterday and now i cant get my ts working, if i try and play wot i have to run in admin mode and i never did before, and now i am having trouble generally chatting and it isnt my headset!!!!! i have 3 new ones and nothing works, not happy about paying for a server that isnt working, what can i do?
    thanks Fi
  3. #63
    March 2011
    39
    Me same problem... -.- OMG TS3 fail... -.-
    Run as admin fixed this for me to btw... But this issue is reeeally an annoying thing for every user who did not run is with admin-rights so far (which is 90-99% of users I guess)... -.- *facepalm*
    Last edited by DanielNL; October 24th, 2012 at 07:51 PM. Reason: Admin rights help
  4. #64
    February 2011
    9
    It appears I only have this issue when the compatibility of a program is set lower. I'm running Windows 8 and, for example, if I'm playing a game such as San Andreas Multiplayer (which I have to set the compatibility to Win98 or else the game crashes), I'm unable to use PTT. This has only applied since the latest update.
  5. #65
    October 2012
    I have roughly the same problem with World of tanks aswell. i can chat to other users on teamspeak when i'm tabbed out of the game, but as soon as i enter the game i go silent according to my mates.
    running windows 7 64-bit
    hope for a quick response/solution
  6. #66
    October 2012
    Netherlands
    This problem also occurs when in World of Tanks.. Voice activation works but push to talk does not..
  7. #67
    October 2012
    Netherlands
    I think this problem relates to this one: http://forum.teamspeak.com/showthrea...ow-PTT-in-game
    Try voice activation, I bet that works.. The 3.0.9 update broke something with 'push to talk' ingame I guess..
  8. #68
    October 2012
    Yes, if right click and launch TS as admin it seems to solve the problem...
  9. #69
    October 2012
    That's not a solution ...
    Quote Originally Posted by jmcu1 View Post
    ... but a workaround only. One that compromises your system's security state. No way!
    3.0.9 is unusable until this will be fixed. When I read through the changelog, I can guess what the cause might be.
  10. #70
    March 2011
    39
    Quote Originally Posted by DC_Bratak View Post
    What would that be?
  11. #71
    October 2012
    Excuse my language but I'm using google translator, here at home has this same problem, but solved clicking with the right mouse button, properties, compatibility tab and selected run this program as administrator-level privileges, however, await a fix this damn bug.
  12. #72
    October 2012
    I had the same problem and more, as it was noticed in some topics, PTT is not works in game.
    The problem was solved using Compatibility mode for TS3 run: "Windows XP SP2", and you can try to run TS3 as administrator.
    Now all work fine.
  13. #73
    June 2012
    Hey guys, i really hope, they fix this Problem, cause i really don't want to run any Software constantly with Admin right.
    And when it's a IM ( call it what you want ) like Programm then i event more don't want to run it. ( Or why TS3 Server's are not running
    with Admin rights too.. ).
    And @DC_Bratak that would me interest too.
    Therefore i had after the Update a fail, and lost all my identities ( for my own luck i had done a export/backup ).
    So: This update was reallly more a "If it ain't broke, don't fix it" or, use the german word: Verschlimmbesserung..
  14. #74
    October 2012
    Ppl Can't Hear Me After 5 Mins.
    Hi.
    This problem started to happen after the last 10mb patch of two days ago. I enter a channel room on ts and people can hear me fine. But after like 5-6 six mins, they cant. (I use push-to-talk button, and when ppl start not hearing me, i go to ts window and check my light. It lights up when i hit the button still.)
    If i exit and re-enter the room they can hear me again for 5 mins, then same thing.
    Anyone knows why this happens ? Thanks in advance.
  15. #75
    October 2012
    Red face Nothing new with 3.0.9.1
    BTW - 3.0.9.1 is out, however it does *NOT* fix that problem.
    Quote Originally Posted by Pr0ctor View Post
    Look at all the changes/additions done to the hotkeys ... easy to break something here. If you compare the log files between 3.0.8.1 and 3.0.9.x you'll also see that the input device enumeration section is missing from the start of the logfile since 3.0.9.x ... don't know if that was intended, no longer needed, or could be a hint to the problem.
    Greetings, DC_Bratak - seines Zeichens hochprofessioneller Verschlimmbesserer ...
  1. Teamspeak doesn't work with my game
    By striker9915 in forum Windows
    Last Post: July 26th, 2013, 05:39 PM
  2. Hotkeys doesn't work in CounterStrike:Source STEAM
    By naonao in forum Bug Reports [EN/DE]
    Last Post: May 18th, 2012, 06:26 PM
  3. Hotkeys in in background or while in game doesn't work
    By Look_Up in forum Bug Reports [EN/DE]
    Last Post: August 11th, 2011, 11:59 PM
  4. TS doesn't work in background
    By Telman in forum macOS
    Last Post: September 25th, 2010, 12:56 AM
