Results 1 to 6 of 6
Thread: Icon problem
    December 2010
    Belgium
    51
    Icon problem
    always wwhhen i start ts it says if i will use it all my settings will be gone so did yes and i had to put all my settings bck but whenn i join a server now the icons do not show up any more can someone help me ?
    this is typed with desktop keyboarrd sorry
    March 2010
    114
    try deleting %appdata%\TS3Client\cache
    December 2010
    Belgium
    51
    doesnt work ;( when i open ts it says : teamspeak 3 cannot write to the configuration file c:/program files/teamspeak 3 client/config/ts3clientui_qt.conf
    May 2010
    6,310
    @Creativee
    Run your client As admin.
    You get this message, because you had change (during the installation) the settings folder. In the installation folder instead the user folder.
    @Maxe
    Before write this method is better to use the normal way (Settings > Options > Security > Clear Cache)
    Because in this case, Creativeee has no TS3Client folder in the appdata folder, but in the installation folder.
    March 2010
    114
    @Maxe
    Before write this method is better to use the normal way (Settings > Options > Security > Clear cache)
    Because in this case, Creativeee has not TS3Client folder in the appdata folder, but in the installation folder.
    Absolutely right, forgot that the config can be located in the installation folder as well as in %appdata%
    December 2010
    Belgium
    51
    i do have ts3client in appdata
  1. icon problem
    By Menzilli in forum General Questions
    Last Post: January 6th, 2014, 04:53 PM
  2. Icon problem
    By BigDeal85 in forum Permission System
    Last Post: February 26th, 2013, 01:46 PM
  3. Icon problem
    By Paradox19 in forum Permission System
    Last Post: May 28th, 2012, 09:55 PM
  4. Icon Problem
    By Mike123 in forum Permission System
    Last Post: January 29th, 2011, 06:59 AM
