Results 16 to 30 of 33
  1. #16
    May 2013
    7
    could you plz tell me what it should be like
  2. #17
    December 2004
    RF
    3,002
    First, as said above,
    ; <<>> DiG 9.9.7 <<>> _ts3._udp.the-dirty-dozen.com. SRV
    ;; global options: +cmd
    ;; Got answer:
    ;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 17516
    However,
    ; <<>> DiG 9.9.7 <<>> _ts3._udp._ts3._udp.the-dirty-dozen.com. SRV
    ;; Got answer:
    ;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 22348
    ;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 13, ADDITIONAL: 25
    ;; OPT PSEUDOSECTION:
    ; EDNS: version: 0, flags:; udp: 4096
    ;; QUESTION SECTION:
    ;_ts3._udp._ts3._udp.the-dirty-dozen.com. IN SRV
    ;; ANSWER SECTION:
    _ts3._udp._ts3._udp.the-dirty-dozen.com. 3600 IN SRV 1 10 11697 ts3.the-dirty-dozen.com.
    In short, leave the "Name" section blank. It is to specify a separate host for a service. You don't need it - you're describing a service for domain.
    Second.
    The domain (@) A record is irrelevant in your setup. I don't know, why you showed it. It could point to your guild website or whatever - it is IRRELEVANT.
    The relevant record is listed in SRV record - ts3.the-dirty-dozen.com, and that one should point to the IP of the voilce server you've rented.
    P.S.
    Next time you have the urge to leave some information out, ask yourself - do you want to get any help? How could people be able to help you, if they don't have the necessary information?
  3. #18
    December 2004
    RF
    3,002
    There are two IPs associated with the A record;
    That's hardly an issue of record setup. That can be a routing issue, but let's discuss it when we have the setup all proper.
  4. #19
    January 2016
    linking my custom domain to my Teamspeak server.
    I recently started renting a Teamspeak server from well known Teamspeak provider for a community that I am growing.
    Coming to towards the final steps and finishing the Teamspeak server now I thought it was time to connect my custom GoDaddy domain to my Teamspeak server so that members of the community can connect via my custom domain, I will also say that this domain is also currently in use for a website I own as well. After being in contact with the Teamspeak server provider they told be that they do not offer technical support in this area and that I will have to spend $35 for a hour of admin for personal support on this. So instead of blowing $30 odd dollars I thought I'd ask first for community advise. So my question is: How do I link my Go Daddy custom domain to my Teamspeak server.
  5. #20
    December 2004
    RF
    3,002
    Try reading the topic.
  6. #21
    February 2012
    571
    The generic answer to this kind of task: If you own a domain and want your domain (or a hostname on this domain) point to your Teamspeak server, go to the management interface of your domain and add a A record and optionally a SRV record.
    The A record has to point to the IP address of your Teamspeak server. This creates a hostname for this IP address.
    The SRV record has to point to a hostname of your Teamspeak server, for example to the A record you created in the 1st step. If your Teamspeak-server is already known under a different hostname, you can point the SRV record to that name as well.
  7. #22
    March 2016
    Setting up TS with a custom domain
    Hello, so I recently purchased a new Domain for my TS server from GoDaddy. I've set up the A record under the DNS management, which allows me to connect to the custom IP with the port on the end, which is (for example, not the real one) ts.abcts3.org:9990, but I want to be able to just join via ts.abcts3.org, now in order to do that, I know I have to create a new SRV record but I'm a bit confused on how to fill out the boxes when I go to create it.
    I was hoping that if I give the information I currently have, someone could tell me what to fill each box with.
    server IP (not real one) - 45.165.132.152:9990
    A record I set up allows me to join on - ts.abcts3.org:9990
    I want to be able to join on ts.abc123.org, in order to do this, I need to create a SRV record, this is the information required to create one
    Name (This is the domain name for which the record is valid.)
    Target (The target is the host name providing the service.)
    Protocol (The name of the protocol, preceded by an underscore character (_).)
    Service (The name of the service, preceded by an underscore character (_).)
    Priority (Priority ranks the importance of the service. Values range from 0 to 65535, where the lowest number represents the highest importance.)
    Weight (Weight is used to determine the order of execution when more than one service has the same priority. Its values range from 0 to 65535. The higher the value, the more weight a service is given.)
    Port (The port number specifies on which port the service runs.)
    If anyone could help with this I'd really appreciate it, thanks
  8. #23
    June 2016
    TS3 Domain forwarding through GoDaddy
    So I'm having issues getting a subdomain to forward to our TS3 IP. I've found other tutorials and solved threads related to this, but I still can't seem to get it to work. Maybe I just haven't waited long enough, but it's been about 48 hours now, and I just want to double check with some more knowledgeable people if I've done something wrong. I talked to a couple GoDaddy support agents, but they didn't seem to have any idea what I was talking about.
    Server provider: multiplayservers
    Server IP: 85.236.101.154:11157
    Provided custom IP: 2800603.ts3.multiplaygameservers.com
    Attempted subdomain: ts.phoenixwingcrew.com
    I've included what I believe to be all the important information (pics) below:
    http://imgur.com/a/Quhh0
    Any help is greatly appreciated!
    *Additional:
    I did put in ts.phoenixwingcrew.com into those records, and upon saving, it would shorten it down to just "ts".
  9. #24
    February 2012
    571
    Your SRV record is fine and works.
    But your "Provided custom IP" of 2800603.ts3.multiplaygameservers.com resolves to 85.236.96.30, while you claim your TS server is on 85.236.101.154.
    So any TS client will try to connect to 85.236.96.30, whatever that is.
    Solution:
    In your screenshot, you made an A record for a hostname ts.phoenixwingcrew.com (the second entry in the screenhot), that points to 85.236.101.154. You can use that in your SRV entry. So in your SRV entry, replace 2800603.ts3.multiplaygameservers.com with ts.phoenixwingcrew.com. You can use any other A record as well, as long as it points to 85.236.101.154.
    Your interface shortens names in the "name" column and makes them relative to your domain. Everything you enter there must be relative to your domain.
  10. #25
    June 2016
    Hm, that's strange. That is the custom host name they provided to us. Both the IP and custom name lead to the same TS with no issue.
    I'll try changing the target in the SRV to ts.phoenixwingcrew.com. So this is what it looks like now: http://imgur.com/pvoDaLn
    *Edit:
    And bingo, that did the trick! Thanks for the tip.
  11. #26
    6,076
    Reason is simply that gameservers uses SRV records themselves already. The "custom IP" they provided you with has an SRV record that directs clients to sid749440.ts3.multiplaygameservers.com, which in turn is 85.236.101.154
  12. #27
    December 2004
    RF
    3,002
    If your target is an SRV record itself, you can use CNAME instead of SRV.
    I.e. "2800603.ts3.multiplaygameservers.com" is an SRV record
    ;_ts3._udp.2800603.ts3.multiplaygameservers.com.    IN SRV
    ;; ANSWER SECTION:
    _ts3._udp.2800603.ts3.multiplaygameservers.com. 600 IN SRV 0 5 11157 sid749440.ts3.multiplaygameservers.com.
    ;; ADDITIONAL SECTION:
    sid749440.ts3.multiplaygameservers.com. 3600 IN A 85.236.101.154
    To maintain your connectivity and be independent of the SRV RR target changes, you can set up CNAME on your side to point to the SRV provided:
    _ts3._udp.phoenixwingcrew.com. IN CNAME _ts3._udp.2800603.ts3.multiplaygameservers.com.
    Now, if you try to connect your TS3 client to phoenixwingcrew.com., it will hop though all the loops for you and correctly discover the actual IP address:port of your rented TS3.
  13. #28
    June 2016
    Godaddy subdomain issues
    I have a Multiplay hosted TS3 and my godaddy domain.
    I tried using SRV and an A host record to use ts.mydomain.com to connect to the TS and after waiting it still hasnt worked.
    I then saw a post about using CName to use a url they give me to do the same job without needing a SRV but this too didnt work.
    Below is the SRV settings, can someone tell me where I went wrong?
    The CName was like this.
  14. #29
    December 2004
    RF
    3,002
    SRV record MUST point to A record, or be itself a CNAME.
    Your current records seems functional, though not quite correct.
    And http://forum.teamspeak.com/threads/1...288#post383288
  15. #30
    October 2016
    Use my Go Daddy host and domain to host a Teamspeak server?
    Hi all! I have a domain account and domain name registered through GoDaddy. I have yet to use that domain for anything (www.simpleprimate.net) except some email addresses.
    I have had a hosting account through Typefrag for a Teamspeak server for quite a few years, but I can not afford to renew it this year.
    I would like to set up my own personal server, and set it to go through that domain name, if possible.
    I do not have a static IP address through my ISP and at this time I do not think I can get one.
    I am using Windows 10.
    Any information would be greatly appreciated!
    Sam
  1. [Resolved] Custom hostname for ts3 server.
    By brisk in forum Server Support
    Last Post: November 8th, 2016, 07:53 AM
  2. [Resolved] SRV Record on GoDaddy (TS3)
    By leettari in forum General Questions
    Last Post: August 13th, 2014, 02:19 PM
  3. GoDaddy and libc.so.6
    By peach.6004 in forum Linux / FreeBSD
    Last Post: October 22nd, 2012, 12:47 PM
  4. hosting on godaddy.com
    By CaptainHansolo in forum Off Topic
    Last Post: October 7th, 2011, 01:20 PM
  5. hosting on godaddy.com
    By CaptainHansolo in forum Server Support
