Page 3 of 3 FirstFirst 123
Results 31 to 33 of 33
  1. #31
    November 2016
    The Answer for all!
    Hello all,
    I have years of experience with silly little problems like this and I will run you all through the best way to forward and IP to a domain name/host name. Generally your over complicating the problem and the process of setting it up is really easy. Don't ever touch external support which someone suggested, unless you want people accessing your IP (even worse if your hosting of your own home network).
    Most of you seem to be working with GoDaddy, I have never seen GoDaddy's management panel as I host everything myself of a web-server but I will run through the process of forwarding a TS IP & Port to a domain name.
    • The first thing you will need is a sub-domain, call it ts.website.com.
    • After making the sub-domain your going to need an A record to point the sub-domain at the IP Address of your TS Server. An A record is literally only good for mapping a domain name to an IP Address so make good use of it. Make sure to keep the time to live as low as possible.
    • Once setting up the A record you can go ahead set up a service record which I have seen plenty of examples above. Make sure to target the sub-domain in this case ts.website.com.
    In coordination with your question Sam using a dynamic IP to link with a domain name would be a massive pain in the arse and rather over complicated and require you to host your own web server and have a script running always looking for an IP change to update the DNS Records. The best way to over come this is try and get a static IP and link the domain with the above steps.
  2. #32
    December 2004
    RF
    3,002
    The above post is wrong from top to bottom.
  3. #33
    February 2019
    Forwayrding a ts3 ip with port to domain name ..
    I need help, i bought a ts3 server from gameservers and a domain from godaddy. and i want the ts3 ip to change to my domain .. i have gotten the accual ip forwarded but i have no clue how to forwayd the port.. please help .
  1. [Resolved] Custom hostname for ts3 server.
    By brisk in forum Server Support
    Last Post: November 8th, 2016, 07:53 AM
  2. [Resolved] SRV Record on GoDaddy (TS3)
    By leettari in forum General Questions
    Last Post: August 13th, 2014, 02:19 PM
  3. GoDaddy and libc.so.6
    By peach.6004 in forum Linux / FreeBSD
    Last Post: October 22nd, 2012, 12:47 PM
  4. hosting on godaddy.com
    By CaptainHansolo in forum Off Topic
    Last Post: October 7th, 2011, 01:20 PM
  5. hosting on godaddy.com
    By CaptainHansolo in forum Server Support
