Results 1 to 11 of 11
    April 2011
    Minnesota USA
    6
    TS3 iphone app connection problem
    When I was trying to connect to my clan TS3 server from my iPhone App, It won't let me tho, cause is it my clan TS3 port to big? "IL2.LeetTS.com:10028"
    I've try re-downloading the app, and I've try re-connecting to my Clan TS3 server, it still will not allow me connect.
    But I was able to connect to another TS3 server, which had a smaller TS port "voice.gameservers.com:9207" and I had no problem with that, without no connection issues.
    Is there anyway to work around this issue? or not, cause I would like to be able to connect on the go. it's always saying "connecting...." but nothing at all.
    January 2003
    53
    Your provider may have filtered ports above a certain range, or even this specific port.
    In what network environment does this error occur, ie public wifi 3g or wlan.
    You might also check if the security level of your identity is high enough for your clan server.
    Hope this helps,
    -Ben
    April 2011
    Minnesota USA
    6
    I'm with Verizon iPhone4 3G data, and for my identity level is at 8
    September 2011
    Hi, I got same problem like you. I cant connect to my clan: "tankai.lt:9988", but I can connect to another. And I need to connect to my team whill I am at work. Im using iphone4.
    April 2011
    Minnesota USA
    6
    Quote Originally Posted by dainiaks View Post
    The trick is, don't use "tankai.lt:9988" all in address box.
    Cause I was able to connect to your TS without no problem bro.
    ie. Address: tankai.lt
    Label: Optional
    Port: 9988
    Nickname: User
    Server Password:
    Identities: Default
    Then u should to be able to connect to ur TS without no problem.
    September 2011
    Thanks bro, you saved me. Hope you gonna find the way to connect to your clan. Thanks again.
    April 2011
    Minnesota USA
    6
    You're welcome bro, and thanks but I already figure it out right now. The trick is, that u need the address to be lower case letters. Cause I was inputting "IL2.LeetTS.com" instead of "il2.leetts.com". So I connected without no problem. Which I am happy about
    September 2011
    My teamspeak server is TX2.LeetTS.com:10024 - and I cannot connect. I tried to do all of the characters in lower case, as one person suggestion, with no help. I do not get an error message - it simply wont connect!
    January 2003
    53
    Please make sure that you dont put the port into the adress field, but in the "PORT" field.
    -Ben
    September 2011
    How do you change the security from 8 to a lower level.
    December 2011
    Hi, i am using a iphone 4 32gb, and i am unable to connect to my clans TS3 server...
    the address is ts44.gameservers.com:9207
    in the address bar on my TS3iPhone app, i have
    label has been left blank
    server port i have put 9207
    nickname has been entered
    and password has been entered
    yet it sits there saying connecting and does not connect?
    any ideas?
  1. Replies: 1
    Last Post: August 18th, 2013, 06:01 PM
  2. Connection problem
    By Thanki in forum General Questions
    Last Post: June 13th, 2012, 06:00 PM
