Page 3 of 3 FirstFirst 123
Results 31 to 37 of 37
  1. #31
    2,699
    Quote Originally Posted by BajVulcho View Post
    I use a cable to connect to the switch.
    I have turned the firewall off.As i said above, i turned "Avast" off too.
    Hello.
    I was asking about the firewall you are using (for exemple, i'm using the windows vista firewall) but it's not now the case.
    Usually this behaviour you have is due to some parameter in the firewall, usually the router firewall, but if other user connected to the same switch can work ok with TS3 maybe the issue was in your computer, in some security software of your computer.
    a) Avast antivirus or Avast Internet Security? (Avast Internet Security includes firewall too)
    b) Maybe the issue is in the connection to the switch --> Have you try using the connection, the ethernet point, of the other user.
    c) Maybe the issue appears when the other user is working --> Have you try when you are alone?
    Sorry, i can only give you ideas.
    Greetings.
  2. #32
    February 2014
    A use on my Pc these:
    Windows 7 64bit
    TeamSpeaker ver: 3.0.13.1 Qtv: 4.8.3
    I use TS my all games (BF3, TF2, Race07, FS13, ........), and it work perfect, but i have a problem in iracing.
    If i start the test in iracing the TS work perfect, but when i start race, quali, practice, join host game few minutes and TS disconnect.
    Disconnect: "Maximum number of connections with the same identity exceeded."
    What my problem?
    Thanks
  3. #33
    November 2015
    Me too
    I need help with this. I have read this thread and tried inclreasing my servers maximum connection count to 99 but that doesn't help. Log:
    <10:44:38> Trying to resolve hostname cptts.gameservers.com
    <10:44:46> Trying to connect to server on cptts.gameservers.com:9149
    <10:44:46> Welcome  to the one and only  Fights Teamspeak Server
    <10:44:46> Connected to Server: "Daniel Loves Fights"
    <11:05:50> Connection to server lost
    <11:05:51> Trying to resolve hostname cptts.gameservers.com
    <11:05:52> Trying to connect to server on cptts.gameservers.com:9149
    <11:05:52> Maximum number of connections with the same identity exceeded.
    <16:35:43> Trying to resolve hostname cptts.gameservers.com
    <16:35:43> Trying to connect to server on cptts.gameservers.com:9149
    <16:35:45> Welcome  to the one and only  Fights Teamspeak Server
    <16:35:45> Connected to Server: "Daniel Loves Fights"
    Looks like it's todo with auto reconnecting, is there a way to increase the time my client wait between autoconnect retries?
  4. #34
    17,374
    Every timeout leaves a clone for some seconds on your server.
    But you will never reach 99 clones with 1 server tab, when the server does work as it should.
    You must increase i_client_max_clones_uid in that server group, you are in.
  5. #35
    April 2017
    hi .
    when i connect to a teamspeak server (any server from any country)
    after 2 - 3 minute i get this error :
    this is full log
    <16:06:19> Maximum number of connections with the same identity exceeded.
    <16:11:01> Trying to resolve hostname ...
    <16:11:04> Trying to connect to server on ...
    <16:11:09> Failed to connect to server
    i check my ping its normal . i test it with my android . everything is ok but in ts3 pc have this problem .
    i reinstall the teamspeak and i update it
    its not problem just for a server . i have this problem in any server
  6. #36
    July 2017
    When I tried to log on for the first time in 24 hours, it kicked me off with this message.
    No one else is using my login. No one knows my login.
  7. #37
    17,374
    This can happen when you timeout and try to connect again.
  1. [No Bug] Maximum number of connections with the same identity exceeded.
    By stevenchamp45 in forum Windows
    Last Post: January 8th, 2014, 03:29 PM
  2. Replies: 22
    Last Post: December 3rd, 2012, 02:05 AM
  3. Maximum number of connections with the same identity exceeded
    By OFAW Nightmare in forum General Questions
    Last Post: September 20th, 2012, 02:31 PM
  4. Replies: 1
    Last Post: March 26th, 2012, 03:12 PM
  5. Maximum number of connections with the same identity exceeded.
    By *{FTB}*FreeJazz in forum Bug Reports [EN/DE]
    Last Post: October 4th, 2011, 07:54 AM
