Page 1 of 3 123 LastLast
Results 1 to 15 of 37
    September 2011
    Maximum number of connections with the same identity exceeded.
    Brand New PC new install of TS3 why do I keep getting this message and getting DC'd after about one min from login in TS3?
    May 2010
    6,310
    Check the i_client_max_clones_uid permission of your server group.
    About the disconnection I guess you get a time out disconnection message, right ?
    September 2011
    Unhappy identity exceeded!
    <19:06:31> Connection to server lost
    <19:06:32> Trying to resolve hostname
    <19:06:33> Trying to connect to server
    <19:06:33> Maximum number of connections with the same identity exceeded.
    this appears after 12-15 sec always when i connect to my guildserver.
    all other servers work perfect for me
    this problem started when i bought new computer , formated etc..
    im using exactly the same client 64 bit TS 3.0.1 as on my old computer.
    talked to the admin if he could raise the limits but did not helped.
    maybe there is some network options i need to fix?
    i have 100Mbit/100Mbit internet with perfect ping in games and all other communication programs aswell as teamspeak 3.
    did not change anything when i installed win 7 ultimate 64.
    had ultimate on old computer aswell.
    red through 40+ sides on this forum and NONE has this problem thats rly creepy thats im the only one
    May 2010
    6,310
    Quote Originally Posted by Undrande
    After this you have to wait 2/3 seconds (your "lost identity" still in memory).
    (i_client_max_clones_uid : value=1)
    For you or he refused ?
    September 2011
    it did not helped for me.
    Becouse of that i think its my computer that is the problem maybe some internet options or network settings.
    tried change identity but no diffrence.
    it worked perfect with the old computer but not with the new thats the strange part, and it is only this one single server i cant use all other servers works perfect.
    May 2010
    6,310
    Ok so if you talk about the connection lost, you're right.
    Maybe it's your connection traffic, firewall, etc.
    You have to check all that could make a lot of traffic.
    October 2011
    I seem to be having the same problem. I am admin and get the message "Maximum number of connections with the same identity exceeded" ocassionally, followed by a connection terminated. Also other people get the message but some have only connected a few times, less that five total. Sometimes it happens once, and i can relog, other times i have to relog several times and then it is fine. A client restart will always fix the issue. I tried to check the permissions of the server group, but could not find the i_client_max_clones_uid. i have 3.0.0 [Build: 14957] on Windows7, 32 bit.
    May 2010
    6,310
    @Azule
    After a "brutal" disconection, the "ghost" client is still present some seconds.
    About the permission, switch on the Advanced permission system.
    And to find this permission, you can use the "Filter" field.
    (Uncheck Show Granted only option)
    November 2011
    Random dissconects
    Getting the following message regulary from ts :
    <15:57:54> Maximum number of connections with the same identity exceeded.
    help please
    *** Thread Merged ***
    November 2011
    Try turning on Upnp think it works now for me
    November 2011
    I keep getting dced every 2 minutes to 2 hours, Its really weird.
    I keep just disconnecting from teamspeak 3 on random times, its really weird. and this comes up <10:36:49> Connection to server lost
    <10:36:50> Trying to resolve hostname ts36.gameservers.com
    <10:36:51> Trying to connect to server on ts36.gameservers.com:9256
    <10:36:51> Maximum number of connections with the same identity exceeded.
    Any help?
    December 2011
    Bugg !??!?!
    i enter in a team speak 3 server( i tried in milions of servers) and after 1 minute , teamspeak disconnect alone and says Maximum number of connections with the same identity exceeded.
    i use a desktop computer ,i use steelseries 4h headphones
    can you help me ?
    Next time please use the forum search function.
    Catalunya
    2,350
    This message has the answer. You have exceeded the allowed clones number.
    If you connect too many times to the same server with the same identity.
    You can set a number greater in:
    Permissions > Server Groups > ... your server group... > Client > Modify > i_client_max_clones_uid
    Another possibility is that you try to reconnect too fast, to the server.
    December 2011
    Can you do it by screenshots or something i cant add i_client_max_clones_uid . i dont understanding. (im guest in server ) "Thanks for the help"
    Catalunya
    2,350
    1- Open advanced system:
    Settings > Options > Application > Misc ... check box "Advanced permissions system" > OK
    2- Set permissions:
    Permissions > Server Groups > ..select your server group... > Client > ... select show names... > i_client_max_clones_uid > value= # (This value defines the max number of additional connections from the same client identity.)
    edit
    Quote Originally Posted by tiagolasxd View Post
    ... (im guest in server ) ...
    Sorry, these instructions are for the ServerAdmin, if you're not, you should talk to him.
  1. [No Bug] Maximum number of connections with the same identity exceeded.
    By stevenchamp45 in forum Windows
    Last Post: January 8th, 2014, 02:29 PM
  2. Replies: 22
    Last Post: December 3rd, 2012, 01:05 AM
  3. Maximum number of connections with the same identity exceeded
    By OFAW Nightmare in forum General Questions
    Last Post: September 20th, 2012, 01:31 PM
  4. Replies: 1
    Last Post: March 26th, 2012, 02:12 PM
  5. Maximum number of connections with the same identity exceeded.
    By *{FTB}*FreeJazz in forum Bug Reports [EN/DE]
    Last Post: October 4th, 2011, 06:54 AM
