Page 4 of 10 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 148
  1. #46
    June 2010
    Exclamation Blacklist check timeout still alive !
    Hey,
    I know there is already a thread about this topic, but it seems it fell into oblivion some months ago.
    So here's the problem: Whenever I try to join on any Server, I get the red Message (translated from german): Connection to the server failed. When I look up in the client protocoll, there is the error message ,,blacklist check timeout'' for every time I try to connect to a server.
    Were there any advancements made concerning this error? The older thread has over 7.000 views and is 4 pages long, so this is a major problem !
    I would really appreciate if anyone could help me with that.
  2. #47
    February 2006
    Texas, USA
    4,143
    Any luck with the TS public server?
  3. #48
    June 2010
    Nope, exactly the same problem there.
  4. #49
    February 2006
    Texas, USA
    4,143
    Do you have any software like a firewall or anti-virus that might be blocking it?
  5. #50
    June 2010
    Both are turned off.
  6. #51
    June 2010
    No further clues?
  7. #52
    May 2006
    Europe/Czech Rep.
    1,616
    ISP blocking, modem blocking. could be several things.
    you can wait for releace of ts3 which will have TCP support.
    but I am afraid thats few of you not only problem.
  8. #53
    June 2010
    Poland
    I have a similar problem. Please help me.
    Can't connect, can't update.
    2010-06-30 18:42:50.824200		Info	Logging started, clientlib version: 3.0.0-beta22 [Build: 11315]
    2010-06-30 18:42:51.265200	ClientUI	Info	TeamSpeak 3 client version: 3.0.0-beta22 [Build: 11315]
    2010-06-30 18:42:51.266200	ClientUI	Info	Qt version: 4.6.2
    2010-06-30 18:42:51.266200	ClientUI	Info	Using configuration location: C:/Users/Tomasz/AppData/Roaming/TS3Client/ts3clientui_qt.conf
    2010-06-30 18:42:51.748200	ClientUI	Info	Last update check was: �r 30. cze 18:36:06 2010
    2010-06-30 18:42:56.207200		Info	Checking for updates...
    2010-06-30 18:42:56.222200		Info	Failed to connect to update server
    2010-06-30 18:42:57.561200		Warning	Failed to write to update server
    2010-06-30 18:46:20.029200	PreProSpeex	Info	Speex version: speex-1.2beta3
    2010-06-30 18:46:20.417200		Warning	Blacklist check error
    2010-06-30 18:46:20.418200		Warning	Failed to write to blacklist server
  9. #54
    August 2010
    Croatia
    6
    Solved [solved] Not Working.. Blacklist timeout problem :/
    2010-08-16 18:51:18.703125 Info Logging started, clientlib version: 3.0.0-beta25 [Build: 11999]
    2010-08-16 18:51:19.062500 ClientUI Info TeamSpeak 3 client version: 3.0.0-beta25 [Build: 11999]
    2010-08-16 18:51:19.062500 ClientUI Info Qt version: 4.6.2
    2010-08-16 18:51:19.062500 ClientUI Info Using configuration location: C:/Documents and Settings/Nikola/Application Data/TS3Client/ts3clientui_qt.conf
    2010-08-16 18:51:19.546875 ClientUI Info Last update check was: pon 16. kol 16:27:53 2010
    2010-08-16 18:51:22.343750 PreProSpeex Info Speex version: speex-1.2beta3
    2010-08-16 18:51:27.921875 Info Blacklist check timeout
    I must say that i can't see any server at ALL! (Web Adress List)
    2010-08-16 18:53:09.718750 Devel TS3ANetwork::Connect failed error: 10060
    Team Speak 2 is working just fine :/
    I'm using XP SP3 and antivirus/firewall is TURNED OFF
    Client Versionbeta 25 and latest ->same problem :/)
  10. #55
    May 2010
    6,310
    Are you sure that the router firewall is off ?
    For blacklist check up the file port (by default 30033).
    For weblist check up the 2010 port.
  11. #56
    18,151
    I never have seen that error "Devel TS3ANetwork::Connect failed error: 10060" in client before.
    Have you tryed to connect to an IP od DNS address?
  12. #57
    August 2010
    Croatia
    6
    Unhappy
    I don't understand what you mean by that.. Can you be a little more specific?
    Quote Originally Posted by florian_fr40 View Post
    Router firewall is OFF, i tried to play with settings (turned off NAT and Firewall etc and combinations of ON and OFF) but there's no progress :/
    My buddies CAN connect to that specific server and to many others but i can't...
    Check up? You mean to FORWARD those ports?
    I can't connect even to TS PUBLIC!
    Same reason.. (blacklist timed out)
  13. #58
    18,151
    This is an DNS address with a port voice.teamspeak-systems.de:9987
    and behind that adress you will find an IP and Port 194.97.114.2:9987
    Every DNS address will end up in an IP, but both addresses will reach the same server.
    Such an DNS addres won't change and it's more easy to keep this address in mind.
  14. #59
    May 2010
    6,310
    Other idea, I see in your first post, you have beta 25 client version.
    If you update your client, have you the same error ?
  15. #60
    August 2010
    Croatia
    6
    Exclamation
    Same all Same all,Florian..
    25 or 26 = same problem
    @dante
    I'm gonna try to connect to DNS now.
    EDIT:
    IP or DNS = NO SUCESS
    i can't even UPDATE CLIENT because it says:
    2010-08-17 12:28:47.906250 Info Update check timeout
  1. Blacklist check timeout
    By Nightfish23 in forum Windows
    Last Post: December 30th, 2013, 10:03 PM
  2. [Resolved] Fails to connect, Blacklist check timeout.
    By -Fr0zn- in forum Windows
    Last Post: February 29th, 2012, 10:23 PM
  3. Replies: 5
    Last Post: January 18th, 2011, 11:34 PM
