Page 5 of 10 FirstFirst ... 34567 ... LastLast
Results 61 to 75 of 148
  1. #61
    18,513
    Ok next try.
    Please download the latest client (beta26) http://www.teamspeak.com/?page=downloads
    and try to connect to server 194.97.114.2:9987
  2. #62
    August 2010
    Croatia
    6
    Thumbs down
    2010-08-17 19:53:23.828125 Info Logging started, clientlib version: 3.0.0-beta26 [Build: 12040]
    2010-08-17 19:53:24.421875 ClientUI Info TeamSpeak 3 client version: 3.0.0-beta26 [Build: 12040]
    2010-08-17 19:53:24.421875 ClientUI Info Qt version: 4.6.2
    2010-08-17 19:53:24.421875 ClientUI Info Using configuration location: C:/Documents and Settings/Nikola/Application Data/TS3Client/ts3clientui_qt.conf
    2010-08-17 19:53:24.843750 ClientUI Info Last update check was: uto 17. kol 00:01:53 2010
    2010-08-17 19:53:51. PreProSpeex Info Speex version: speex-1.2beta3
    2010-08-17 19:53:56.187500 Info Blacklist check timeout
    Nothing -.-
  3. #63
    August 2010
    Croatia
    6
    New idea anyone?
  4. #64
    June 2010
    Poland
    BUMP.
    Can anyone help me?
  5. #65
    August 2010
    Croatia
    6
    Exclamation
    SOLVED!
    I turned off my firewall(commodo firewall) but some of the processes were STILL RUNING!
    So i switched it to INSTALLATION mode and voila!
    I re-installed TS last client version 26 and now is working just fine.
    Mod can lock this thread!
    Thanks for your help!
  6. #66
    18,513
    Good to know! =)
    *i removed all your empty lines
  7. #67
    18,513
    Please read this, maybe it helps you (and others) to solve your problem.
    http://forum.teamspeak.com/showpost....6&postcount=11
  8. #68
    October 2009
    germany
    mhh...
    checked router ports, firewall and anti virus processes off (checked if any running still), turned router firewall off, reinstalled...
    worked back on an .1x version, updated and ... >.<
    sadly havn;t the installer of that earlier version anymore.
    any ideas?
    2010-08-25 15:13:21.531250|INFO | | | Logging started, clientlib version: 3.0.0-beta26 [Build: 12040]
    2010-08-25 15:13:22.296875|INFO |ClientUI | | TeamSpeak 3 client version: 3.0.0-beta26 [Build: 12040]
    2010-08-25 15:13:22.296875|INFO |ClientUI | | Qt version: 4.6.2
    2010-08-25 15:13:22.296875|INFO |ClientUI | | Using configuration location: D:/Programme/TeamSpeak 3 Client/config/ts3clientui_qt.conf
    2010-08-25 15:13:22.765625|INFO |ClientUI | | Last update check was:
    2010-08-25 15:13:22.765625|INFO | | | Checking for updates...
    2010-08-25 15:13:24.062500|INFO |PreProSpeex | 1| Speex version: speex-1.2beta3
    2010-08-25 15:13:27.875000|INFO | | | Update check timeout
    2010-08-25 15:13:29.296875|INFO | | | Blacklist check timeout
    edit:
    also tried via DNS and IP, doesn't make a difference...
  9. #69
    September 2010
    brisbane
    Hey im having trouble connecting to all ts3 servers
    its saying:
    2010-09-12 20:17:15.518388 Info Logging started, clientlib version: 3.0.0-beta29 [Build: 12268]
    2010-09-12 20:17:15.723400 Query Info listening on 127.0.0.1:25639
    2010-09-12 20:17:16.362436 ClientUI Info TeamSpeak 3 client version: 3.0.0-beta29 [Build: 12268]
    2010-09-12 20:17:16.362436 ClientUI Info Qt version: 4.6.2
    2010-09-12 20:17:16.363436 ClientUI Info Using configuration location: C:/Users/Sean/AppData/Roaming/TS3Client/ts3clientui_qt.conf
    2010-09-12 20:17:16.813462 ClientUI Info Last update check was: Sun 12. Sep 10:01:26 2010
    2010-09-12 20:17:19.806633 PreProSpeex Info Speex version: speex-1.2beta3
    2010-09-12 20:17:24.974929 Info Blacklist check timeout
    2010-09-12 20:17:32.819378 Info Blacklist check timeout
    Anyone know how i might be able to fix this?
  10. #70
    May 2010
    6,310
    The 2008 port is open/forwarded on your firewall or/and your router ?
  11. #71
    September 2010
    Kiev
    Quote Originally Posted by Edwards93 View Post
    its saying:
    I decided.
    Has removed. Even the registry is not cleaned.
    I downloaded teamspeak3-client-win32-3.0.0-beta17.
    To update.
    Earned.
  12. #72
    August 2010
    NZ
    9
    Same issue here
    2010-09-14 10:59:03.312831 Info Logging started, clientlib version: 3.0.0-beta29 [Build: 12268]
    2010-09-14 10:59:03.349831 Query Info listening on 127.0.0.1:25639
    2010-09-14 10:59:03.750831 ClientUI Info TeamSpeak 3 client version: 3.0.0-beta29 [Build: 12268]
    2010-09-14 10:59:03.750831 ClientUI Info Qt version: 4.6.2
    2010-09-14 10:59:03.750831 ClientUI Info Using configuration location: C:/Users/xxxx/AppData/Roaming/TS3Client/ts3clientui_qt.conf
    2010-09-14 10:59:04.219831 ClientUI Info Last update check was: Tue 14. Sep 10:45:50 2010
    2010-09-14 10:59:04.225831 PreProSpeex Info Speex version: speex-1.2beta3
    2010-09-14 10:59:09.805831 Info Blacklist check timeout
    I notice this post here mentions a firewall
    Im using a firewall, but checking all the logs from my IP while connecting there are no denies, and i even setup a rule called 'Allow anything from anywhere to anywhere from any user' and it still doesnt work
  13. #73
    February 2010
    Italy
    12
    I'm still having the problem (http://forum.teamspeak.com/showpost....0&postcount=13). There are other posts of mine at the beginning of this topic.
    Ts crashes after some seconds/minutes/hours and also the adsl connection with it. -.- I've been searching for solution since 8 MONTHS ago, but nothing. Pls help.. try to discuss. The only thing that I've discovered is that the more people there are, the less time I have before crash.
    Latest version 3.0.0beta-32.
  14. #74
    October 2009
    germany
    still noone has any idea to solv this blacklist error thing?
    always tried on every new version since months with all different setting - it's always the same to me...
  15. #75
    November 2010
    France
    2010-11-19 10:43:42.211074 Info Blacklist check timeout
    2010-11-19 10:43:53.117254 Info Blacklist check timeout
    2010-11-19 10:44:43.210684 Info Blacklist check timeout
    I am also having this problem. I have uninstalled version 36 and switched to version 26, but it has not helped.
    The most bizarre part of the problem is that it is not for all connections, but only certain connections on certain server ports.
    For example, I can connect to ts.distorzion.com:8778
    But I cannot connect to ts.distorzion.com:9999
    Both server ports report the blacklist timeout error, but for some reason, 8778 lets me log in, and 9999 fails to connect.
    Any suggestions?
  1. Blacklist check timeout
    By Nightfish23 in forum Windows
    Last Post: December 30th, 2013, 11:03 PM
  2. [Resolved] Fails to connect, Blacklist check timeout.
    By -Fr0zn- in forum Windows
    Last Post: February 29th, 2012, 11:23 PM
  3. Replies: 5
    Last Post: January 19th, 2011, 12:34 AM
