Results 1 to 5 of 5
    September 2011
    Ireland
    Connection Issues !Help!
    Hey everyone i need help with this , when i go onto teamspeak its disconnected it wont connect to any server and it wont even connect to the web list server if anyone know how to fix this Pleas Tell ! thanks
    May 2010
    6,310
    If I undersrand you, when you connect on a Teamspeak server, you are disconnected and you can't connect to any other server ?
    What is the error message ?
    Do you get some informations in the client log ?
    September 2011
    Ireland
    22/09/2011 15:46:17 Info Logging started, clientlib version: 3.0.1 [Build: 15001]
    22/09/2011 15:46:19 Direct Sound Debug setting timer resolution to 1ms
    22/09/2011 15:46:22 Info Registering plugin command id: {8cd82610-2713-40bb-8094-acc4a903b370} appscanner_plugin
    22/09/2011 15:46:24 Query Info listening on 127.0.0.1:25639
    22/09/2011 15:46:24 Info Registering plugin command id: {7fec23f3-bd97-477f-915e-20d44c2ee4d2} clientquery_plugin
    22/09/2011 15:46:29 Info Registering plugin command id: {5a2bcd72-46ad-404d-8cb7-55f9b353278c} dx_overlay_plugin
    22/09/2011 15:46:32 Info Registering plugin command id: {95831d1a-68da-4283-b6f7-b411e06ef9eb} lua_plugin
    22/09/2011 15:46:32 Info Registering plugin command id: {7230c472-04d0-4366-9f59-5f31b2f5f0af} test_plugin
    22/09/2011 15:46:58 ClientUI Info TeamSpeak 3 client version: 3.0.1 [Build: 15001]
    22/09/2011 15:46:58 ClientUI Info Qt version: 4.7.2
    22/09/2011 15:46:58 ClientUI Info Using configuration location: C:/Users/Mark/AppData/Roaming/TS3Client/ts3clientui_qt.conf
    22/09/2011 15:46:59 ClientUI Info Last update check was: Thu 22. Sep 15:35:39 2011
    22/09/2011 15:46:59 Input Info Input device name: Mouse
    22/09/2011 15:46:59 Input Info Input device name: Keyboard
    22/09/2011 15:48:27 Info No TSDNS found at "ginn.zebgames.com"
    22/09/2011 15:48:27 Info No TSDNS found at "zebgames.com"
    22/09/2011 15:48:27 Windows Audio Session Debug WAS:penDevice-enter
    22/09/2011 15:50:02 Windows Audio Session Debug WAS Buffer size: 960
    22/09/2011 15:50:02 Windows Audio Session Debug WAS:penDevice-leave
    22/09/2011 15:50:02 Windows Audio Session Debug WAS::startDevice-enter
    22/09/2011 15:50:03 Windows Audio Session Debug WAS::startDevice-leave
    22/09/2011 15:50:03 Windows Audio Session Debug WAS:penDevice-enter
    22/09/2011 15:50:03 Windows Audio Session Debug WAS Buffer size: 960
    22/09/2011 15:50:03 Windows Audio Session Debug WAS:penDevice-leave
    22/09/2011 15:50:03 PreProSpeex Info Speex version: speex-1.2beta3
    22/09/2011 15:50:03 Windows Audio Session Debug WAS::startDevice-enter
    22/09/2011 15:50:09 Info Blacklist check timeout
    22/09/2011 15:50:45 Error TS3ANetwork::Connect failed error: 10013
    Thats what errors there is and i cant even access the client log :/
    May 2010
    6,310
    Ok, so for test
    Turn off all firewall and/or anti-virus.
    Try to re install the client.
    September 2011
    Ireland
    No that dident work :/
  1. IP / Connection Issues
    By Tek_NSA in forum Windows
    Last Post: August 8th, 2015, 11:55 PM
  2. Connection Issues
    By Neytiri in forum Server Support
    Last Post: April 27th, 2013, 04:21 AM
  3. Need help with connection issues.
    By Evolution16 in forum Server Support
    Last Post: May 5th, 2012, 07:37 PM
