Results 1 to 5 of 5
    October 2011
    Database corrupt? Help please!
    Hi all. I recently setup a TS3 server (2 weeks ago) Everything was working perfectly (all the channels setup, admins, clients etc etc. and have had 0 issues over the last 2 weeks). I finally decided it was time to do some maintenance on our dedicated server - basically a reboot as it's been on for 2 weeks straight - and now TS3 will not start up. The icon at the bottom appears for a few seconds then disappears every time. Clicking on the virtual server folder gives me an error stating the file or files is corrupt.
    This is the last log Oct 2:
    2011-10-02 20:42:32.440511|INFO |ServerLibPriv | | Server Version: 3.0.0 [Build: 14957], Windows
    2011-10-02 20:42:32.441511|INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2011-10-02 20:42:32.441511|INFO |DatabaseQuery | | dbPlugin version: 3.7.3
    2011-10-02 20:42:32.441511|INFO |DatabaseQuery | | checking database integrity (may take a while)
    2011-10-02 20:42:32.476513|INFO |SQL | | pruning old database log entries where timestamp is older than 90 days
    2011-10-02 20:42:33.192554|INFO |Accounting | | Licensing Information
    2011-10-02 20:42:33.192554|INFO |Accounting | | type : Non-profit
    2011-10-02 20:42:33.192554|INFO |Accounting | | starting date : Thu Sep 29 00:00:00 2011
    2011-10-02 20:42:33.192554|INFO |Accounting | | ending date : Sat Sep 29 00:00:00 2012
    2011-10-02 20:42:33.192554|INFO |Accounting | | max virtualservers: 10
    2011-10-02 20:42:33.192554|INFO |Accounting | | max slots : 512
    2011-10-02 20:42:33.223556|INFO |FileManager | | listening on 0.0.0.0:30033
    2011-10-02 20:42:33.324562|INFO |VirtualServer | 1| listening on 0.0.0.0:9987
    2011-10-02 20:42:33.324562|INFO |CIDRManager | | updated query_ip_whitelist ips: 127.0.0.1,
    2011-10-02 20:42:33.326562|INFO |Query | | listening on 0.0.0.0:10011
    2011-10-02 20:56:48.187457|INFO |GetWanIP | | WAN ip: 216.52.148.29
    2011-10-01 05:27:05.480096|INFO |GetWanIP | | WAN ip: 216.52.148.29
    2011-10-01 05:35:58.841603|INFO |VirtualServer | 1| stopped
    And now this is what the log is showing every time I try and start it:
    2011-10-14 14:06:43.115731|INFO |ServerLibPriv | | Server Version: 3.0.0 [Build: 14957], Windows
    2011-10-14 14:06:43.116731|INFO |DatabaseQuery | | dbPlugin name: SQLite3 plugin, Version 2, (c)TeamSpeak Systems GmbH
    2011-10-14 14:06:43.117731|INFO |DatabaseQuery | | dbPlugin version: 3.7.3
    2011-10-14 14:06:43.117731|INFO |DatabaseQuery | | checking database integrity (may take a while)
    2011-10-14 14:07:16.366633|ERROR |DatabaseQuery | | db_exec failed disk I/O error
    2011-10-14 14:07:16.366633|ERROR |DatabaseQuery | | integrity_check faileddisk I/O error
    2011-10-14 14:07:16.367633|CRITICAL|ServerLibPriv | | Server() DatabaseError disk I/O error
    The machine has 920gb of free disk space and 54 gigs of DDR3 on a 10gbps connection. What could have possibly caused the database to be corrupt by a simple restart? And how do I fix it?
    Any help is appreciated.
    Thanks.
    May 2010
    6,310
    I guess you don't stopn the Teamspeak server before reboot the machine.
    You have to use a tool to reindex all database (if it's not necessary the database must be rebuild).
    You can use a tool like SQLite Expert Personnal (google )
    Please before anythings, make a backup of your broken database and log file.
    October 2011
    Quote Originally Posted by florian_fr40 View Post
    No I didn't stop it. Just like I don't stop steam, or the volume properties, or any other little icon down at the lower right hand corner of the screen that is running. I had no idea that teamspeak had to be stopped manually unlike every other icon on that side of the window. Strange something as simple as a reboot would corrupt it.
    I've downloaded SQLite and tried to reindex and recieved an I/O error every time. Any other suggestions?
    May 2010
    6,310
    Arg, the second solution will be to rebuild the entire database.
    If you are not famialr with sql, send me your database in private message, I'll try to rebuild it without losing data.
    October 2011
    I sent you a pm with the db. I had to convert it to text as it would not let me copy the file.
    Thanks for the help!
  1. [No Bug] Permission flaw found allows user to corrupt whole database
    By ChewyBar in forum Bug Reports [EN/DE]
    Last Post: February 16th, 2015, 10:40 AM
