Results 1 to 4 of 4
    October 2011
    Solved Help needed - TS3 x86 installation on Ubuntu 11.10 (oneiric)
    First of all, I'd like to apologize if I'm breaking any forum rules posting this like I am. Hopefully, I'm not, so lets continue to the issue I'm having.
    I've downloaded and extracted latest x86 linux server. I've also made 2 ini files :
    ts3.server.ini :
    default_voice_port=11337
    filetransfer_port=11338
    filetransfer_ip=127.0.0.1
    query_port=11339
    query_ip=127.0.0.1
    dbplugin=ts3db_mysql
    dbpluginparameter=ts3db_mysql.ini
    ts3db_mysql.ini:
    [config]
    host=localhost
    port=3306
    username=teamspeakuser
    password=teamspeakpass
    database=teamspeakdatabase
    socket=
    After doing all that, I tried starting my server via startup script you guys provided :
    ./ts3server_minimal_runscript.sh inifile=ts3server.ini
    And I'm getting following problem :
    2011-10-21 13:40:54.334715|INFO |ServerLibPriv | | Server Version: 3.0.0 [Build: 14957], Linux
    2011-10-21 13:40:54.335359|INFO |DatabaseQuery | | Please make sure you use the supplied ts3server_minimal_runscript.sh to run the server, or set LD_LIBRARY_PATH yourself
    2011-10-21 13:40:54.335413|CRITICAL|DatabaseQuery | | unable to load database plugin library "libts3db_mysql.so", halting!
    ldd libts3db_mysql.so provides following information :
    linux-gate.so.1 => (0xf776e000)
    libmysqlclient.so.15 => not found
    libstdc++.so.6 => /usr/lib32/libstdc++.so.6 (0xf7665000)
    libm.so.6 => /lib32/libm.so.6 (0xf763a000)
    libgcc_s.so.1 => /usr/lib32/libgcc_s.so.1 (0xf761c000)
    libc.so.6 => /lib32/libc.so.6 (0xf74a2000)
    /lib/ld-linux.so.2 (0xf776f000)
    So I tried to install it : sudo apt-get install libmysqlclient15off
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    libmysqlclient15off is already the newest version.
    Then I downloaded the package and tried to install it manually :
    sudo dpkg -i libmysqlclient15off_5.0.51a-3ubuntu5.8_i386.deb
    dpkg: error processing libmysqlclient15off_5.0.51a-3ubuntu5.8_i386.deb (--install):
    libmysqlclient15off:i386 5.0.51a-3ubuntu5.8 (Multi-Arch: no) is not co-installable with libmysqlclient15off:amd64 5.1.30really5.0.75-0ubuntu10.5 (Multi-Arch: no) which is currently installed
    Errors were encountered while processing:
    I'm really running out of ideas here. I've seen a lot of people having same or similar problems on this and some other forums, but their solutions obviously didn't help me solve this..
    Help out please : )
    May 2010
    6,310
    Quote Originally Posted by jagermeister
    Your system is a 32 or 64 bit ?
    October 2011
    Hello florian,
    It's 64bit system.
    You gave me additional idea by asking that question, so I downloaded 64bit version of teamspeak server and made all those ini files from above. When I try to run it same way, I get following error :
    TeamSpeak Server 3.0.0 [Build: 14957]
    (c)TeamSpeak Systems GmbH
    Logging started
    2011-10-23 10:54:09.302095|INFO |ServerLibPriv | | Server Version: 3.0.0 [Build: 14957], Linux
    2011-10-23 10:54:09.363513|INFO |DatabaseQuery | | dbPlugin name: MySQL plugin, (c)TeamSpeak Systems GmbH
    2011-10-23 10:54:09.363582|INFO |DatabaseQuery | | dbPlugin version: 1
    2011-10-23 10:54:09.420219|ERROR |DatabaseQuery | | db_exec() CREATE TABLE channel_properties ( server_id integer unsigned, id error: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'AUTOINCREMENT NOT NULL, channel_parent_id integer unsigned, server_id ' at line 1
    2011-10-23 10:54:09.420292|CRITICAL|SQL | | db_CreateTables() unable to create tables
    Then I tried changing the content of ts3server.ini by adding following lines :
    dbsqlpath=sql/
    dbsqlcreatepath=create_mysql/
    and again tried running server to get this:
    Logging started
    2011-10-23 11:02:33.624507|INFO |ServerLibPriv | | Server Version: 3.0.0 [Build: 14957], Linux
    2011-10-23 11:02:33.625636|INFO |DatabaseQuery | | dbPlugin name: MySQL plugin, (c)TeamSpeak Systems GmbH
    2011-10-23 11:02:33.625688|INFO |DatabaseQuery | | dbPlugin version: 1
    2011-10-23 11:02:33.630606|ERROR |DatabaseQuery | | db_exec() CREATE TABLE channel_properties ( server_id int unsigned, id int error: Table 'channel_properties' already exists
    2011-10-23 11:02:33.630677|CRITICAL|SQL | | db_CreateTables() unable to create tables
    And finally .. I've emptied that entire database and ran the script again and it works now : )
    Thanks for help, you gave me great idea : - D
    May 2010
    6,310
    This is the most important
  1. [On Todo] [installation issue] Acceptance of Overwolf EULA needed to install TeamSpeak only
    By Sophira in forum Suggestions and Feedback
    Last Post: January 8th, 2015, 04:52 AM
