Results 1 to 4 of 4
    germany
    16
    ToDo List [Crit-error] While change sound-package settings
    Assertion item->isCheckable() failed at client\clientui\UI_qt\setup\notificationssetup.cpp :717;
    I change my soundpackage-settings in my client (settings -> options > notifications -> special -> "Mic click self on") and want to change the path to "../default/mic_click_on.wav". After i press enter to confirm the changes, the client crashed with the above posted crit-error-message.
    Btw. My client doesn't play my mic clicks since the (beta) client-update to 3.0.2 - the playback-setting ("Own client plays mic clicks") is enabled.
    18,513
    We can reproduce this and will fix that with our upcomming client 3.0.2
    * I mean newer as 3.0.2 (10.11.2011 14:58:35)
    Krün, Germany
    510
    Thanks for the report. The critical error is fixed now.
    Regarding mic click on own client, works fine here. Check if the entry for Notifications / Special / Mic click self on/off is pointing to an existing file and actually plays (use the play button in the notifications options window to test sounds). Check if you are not output muted and have "Play no sounds" set in the notifications options. And check the soundpack settin of your bookmark.
    germany
    16
    Hm yepp, my bad. I had a typo in my sound-settings.ini - sry
  1. Replies: 3
    Last Post: December 21st, 2013, 11:32 PM
  2. [Resolved] Package Installer Error
    By SmokinShark in forum Client Plugins / Lua Scripts
    Last Post: October 10th, 2011, 12:50 PM
  3. Package Installer Error
    By SmokinShark in forum Windows
    Last Post: October 10th, 2011, 08:33 AM
  4. [BUGS] Cannot change 3d sound settings
    By D.I.Y in forum Client Support
    Last Post: December 24th, 2009, 11:19 PM
