Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
  1. #16
    April 2016
    Can anyone point me to information that could help me get creative with my spacers?
    I wanted to make a change to the looks of my Teamspeak but I don't know how to do some of the things I've found online. For example, how do I create spacers that look like this?
    http://forum.teamspeak.com/attachmen...7&d=1354237433
    Thanks. Any other tips of setting up a good looking Teamspeak would be really appreciated. My Teamspeak is very crowded.
  2. #17
    November 2013
    322
    Quote Originally Posted by imWheat View Post
    Whoever manages the server in question, used spacers and "alt key code symbols" to achieve these effects.
    How to create spacers
    - Create a new or edit an existing channel
    - Start the channel name with [xspacer]
    ├ [lspacer] = Channel Name aligned left
    ├ [cspacer] = Channel Name centred
    ├ [rspacer] = Channel Name aligned right
    └ [*spacer] = Anything after will be repeated to fill the whole width of the tree view. Works with multiple symbols and text.
    = [xspacer] is followed by whatever text and/or symbols you want to display in your spacer
    - Example: [lspacer]This spacer is aligned to the left
    - Example: [*spacer]╦╩
    Important: If you want to use several spacers with the same name or the same pattern you need to give the spacer unique names to avoid the error "channel name is already in use". To do that, you simply add (a) character(s) after spacer.
    - Example: [xspacer0] - [xspacer999], [xspacerA] - [xspacerZZZ]
    How to use symbols in the Channel Name (Windows)
    - Scroll to "Windows Accessories" in the start menu and open "Character Map", or search with a search engine for "Alt Codes"
    - Search for symbols you want to use, double-click them, or press "Select", and press "Copy"
    - Edit your channel of choice, highlight the "Name" text box and paste the symbol
    - Example: [cspacer]╦ ╩ ▀ ═ • ▪ ◄ ►
    Example screenshot: https://i.sli.mg/Rowtmy.png
    General tips
    - Keep it as clear and intuitive as possible
    - Keep it organised and categorised
    └ New users and guests should be able to orientate themselves in the server as fast as possible
    └ Have a "natural" flow within the channel sorting. Something like "Lobby -> Public Area -> Member Area -> Admin Area -> AFK Area" will help the user to find their way around
    Last edited by Brady_The; August 4th, 2016 at 06:01 PM. Reason: Added further information by Chris. Thank you.
  3. #18
    April 2016
    Thanks
    Thanks for your help. I do have another question though. How do I get the spacers to reach entirely across like the example I posted? When I do it it looks like this.
    http://imgur.com/a/hWSoW
  4. #19
    6,078
    name it [*spacer]-
    the stuff after the ] will be repeated however many times necessary to fill the width.
  5. #20
    April 2016
    Thanks
    Thanks so much Chris. I really appreciate it.
  6. #21
    December 2016
    How to add spacers
    I think this question is kinda dumb but im new using teamspeak server and I was wondering how can you add the kind of spacers ppl use on ther servers, not sure if they are called spacers that's why I upload a picture to describe it better it says
    ~~~~~~~~~ GAMES ~~~~~~~
    Last edited by dante696; December 15th, 2016 at 07:26 AM. Reason: merged, see post #2
  7. #22
    18
    using cspacer
    is there a way to use the cspacer to make a line of hearts going across is there away to do that
  8. #23
    18,151
    This was answered in post 12, 17 & 19
    [*spacer]♥
  9. #24
    January 2019
    Reply to Thread
    This is an example of what I did:
    (*spacer0)____
    (cspacer1)WELCOME
    (*spacer2)____
    (cspacer3)LOBBIES
    (*spacer4)____
    (cspacer5)FARMING UNLIMITED
    (*spacer6)____
    (spacer7)FLIGHT UNLIMITED
    (*cspacer8)____
    (cspacer9)MODDING UNLIMITED
    (*spacer10)____
    (cspacer11)TRUCKING UNLIMITED
  10. #25
    August 2019
    How can i do this?
    How can i do this?
  11. #26
    18,151
    Quote Originally Posted by Leon4344 View Post
    How can i do this?
    Do what?
    We don't see what you mean. Can you give us some more details?
  12. #27
    November 2016
    105
    Are u talking about channel description or what? The picture seems to be a broken external link if thats your problem...
  13. #28
    August 2019
    This Click image for larger version.
  14. #29
    January 2017
    Switzerland
    413
    Maybe about the spacer...
    [spacer]Channelname
    - there's no channelicon
    [cspacer]center
    - will get a text on the center
    [*cspacer001]___
    [*cspacer002]___
    - this will draw a big line into your server tree, to seperate channels.
    also, check this thread for more informatioms.
    Or what else do you need? Add more informations if you got questions.
  15. #30
    August 2015
    55
    And if you mean the spacer where your mouse is, simply use:
    [*spacer]=
    (And don't forget you will need different names for the spacer if you want the same equal sign (=) used on several spacers, so like [*spacer1]=
    [*spacer2]=
    etc.
    HF and check back. Cheers
  1. PHP Function for the Spacer Channel
    By florian_fr40 in forum Tools / Web Based
    Last Post: December 22nd, 2017, 07:02 PM
  2. How do you make these such spacer
    By ItsDocterrific in forum Client Support
    Last Post: July 1st, 2015, 12:46 AM
  3. Spacer Channel
    By MaGiCPaiN in forum Server Support
    Last Post: December 16th, 2014, 09:27 PM
  4. Replies: 1
    Last Post: January 17th, 2011, 10:00 PM
  5. Spacer text [*spacer#] & icon in TS viewer
    By Kort_Lontje in forum General Questions
    Last Post: November 7th, 2010, 09:30 AM
