Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    Flroida
    65
    Client Modify Permission Problem
    I have been trying to set the client modify permission and needed client modify permission through the teamspeak client however every time I try I get the error, insufficient group modify power even though ignore modify permission is set to 1
    May 2010
    6,310
    The b_permission_modify_power_ignore, is for ignore the comparaison with the grant value.
    But you still need a i_group_modify_power equal or greater than the i_group_needed_modify_power
    Flroida
    65
    then why can't I edit a clients i_client_modify_permission_power or i_needed_client_modify_permission_power. every time I get a insufficient group modify permission even though I am changing a client.
    May 2010
    6,310
    Quote Originally Posted by Whinis View Post
    I repeat myself:
    Quote Originally Posted by Florian
    Check these permissions.
    Flroida
    65
    Both are at 100 with grant power of 100. my question still stands if I am modifying a client and changing the client modify permission why does it check the groups modify permission if they are not in said group? seems kind of backwords.
    18,112
    Please show us the complete error message.
    Please tell me all values of the target group and target client
    i_permission_modify_power
    i_client_permission_modify_power
    i_client_needed_permission_modify_power
    Flroida
    65
    there is no target group. I am trying to modify a client directly though client permissions
    The clients group has the following permissions
    i_permission_modify_power not granted
    i_client_permission_modify_power not granted
    i_client_needed_permission_modify_power not granted
    i_group_modify_power not granted
    i_group_needed_modify_power 30
    i_permission_modify_power 100 grant: 99999999999
    i_group_modify_power 100
    i_group_needed_modify_power not granted
    My group has 100 for all except client permission and needed which are not granted
    error is <12:34:11>insufficient permission modify power when trying to set to value of 100 or
    <12:34:42>insufficient permission group modify power when trying to set to a value of 14-100
    anything less than 14 it allows me to set
    18,112
    The Grant Value for a permisions has to be equal or lower as the i_permission_modify_power to edit a permission!!!!!!!
    << What permission do you mean?
    Flroida
    65
    Both i_client_modify_power and i_client_needed_modify power. I can set a value from 0-14 but not higher that 14. Also the grant power was an attempt to allow me to modify it however the grant power can be not set and no change.
    18,112
    This is weired and are you sure, that there is no grant value of 14 somewhere in your permissions?
    Maybe from client permissions or in your server groups or channe lclient permissions???
    Flroida
    65
    none that I can see via database search or through powers overview
    18,112
    Can you send me your server database in a private message? (You are online, when i'm out of work and so i can have a look at it tomorrow)
    Please tell me,
    What Server Group do you own,
    What Client or Group do you try to edit,
    and at least you server version.
    Flroida
    65
    Private message sent, server version because I forgot to include it is 3.0.0. build 14957
    18,112
    The whole server permissions are crazy!!! Please do not play with our default groups :-/
    Your Server Admin owns Query Permissions and the Server Query Admin does not have enough power to do anything ......
    The server owner also removed the server admin login from the query group.
    And why do you use the Query Admin as a client group? (We do not recommend that!!!)
    I can see you own the DB ID 177 and a lot of client permissions.
    I can't reproduce, the value 1-14 thingy, but i found that no i_client_permission_modify_power is given in any of your groups.
    When i add it manually to the database (to my client) then it is possible for me, to change your client permissions.
    Flroida
    65
    We had a system admin break into our system a few months back and mess around with the database, I thought I had fixed everything. One of the problems was he deleted all users including superadmin from admin server query so we had to add a new one. What do you recommend that I do?
  1. [Not possible] Increasing group modify and client permission modify above 75
    By Warith in forum Permission System
    Last Post: September 20th, 2015, 02:44 PM
  2. Problem with group modify power permission
    By JGD4182 in forum Server Support
    Last Post: September 1st, 2015, 02:52 PM
  3. [No Bug] Problem with Channel needed Permission Modify Power
    By MajorPain931 in forum Permission System
    Last Post: March 1st, 2014, 02:27 PM
  4. Allow client to modify its own client permission
    By kore12345 in forum Permission System
    Last Post: December 29th, 2012, 01:22 PM
  5. [Resolved] Modify Channel Permission System Problem
    By Keldaria in forum Permission System
    Last Post: March 25th, 2012, 07:48 PM
