Results 1 to 5 of 5
    Bangkok
    8
    Question [Help] How to setup group permission to access private channel without password
    Just want to ask you guys.
    I have setup some of the private channels for certain members. However, to be accessed to the channel they have to enter the password.
    Are there any other way for me, to add these members to the group that once entering this private channel, it doesn't require any password?
    Thank you
    2,698
    For certain members and some channels, you can try allowing to join to the channels without password.
    Attention, that means person+channel combination.
    In the "Channel Client Permissions" Tab, to each "user and channel" activate the "b_channel_join_ignore_password"
    Greetings.
    Secret Base in Arctic Region
    1,671
    This has been removed somewhere around Beta 15 or 16.
    "b_channel_join_ignore_password" can only be set for server groups and clients.
    Better way would be using join_power, since above permission set on server group or client level will apply for all passworded-channel.
    Bangkok
    8
    Thank you guys, will try that. I hope it not stack with other channel with the same join power as well.
    Catalunya
    2,350
    Well, you need play with i_channel_join_power and i_channel_needed_join_power
    For the "Normal" server_group i_channel_join_power value is=50
    Then, you can create these specific channels with i_channel_needed_join_power=60 (e.g.)
    Also, create a Channel_group, named e.g. "Authorizeds" with i_channel_join_power=60, and other necesssary permissions.
    You must assign every authorized user to the channel_group "Authorizeds", when they are into his specific channel
  1. [Resolved] Channel Admin permission overwrite group permission
    By spyder25000 in forum Permission System
    Last Post: February 22nd, 2015, 04:25 AM
  2. [Fixed?] Client without permission can access Server group dialog
    By TotoIsBack in forum Bug Reports [EN/DE]
    Last Post: March 25th, 2011, 07:20 PM
  3. Channel Access setup problem
    By Thirstycamel in forum Permission System
    Last Post: June 24th, 2010, 09:29 AM
