Page 1 of 2 12 LastLast
Results 1 to 15 of 21
    November 2011
    "Connection lost" after more than 5 User are in a Chanel
    since Server Version 3.0.1 I'm having this Issue that no more than 5 Users can join a Channel. Every Person after that get's "connection timed out". (Connection lost)
    There are no specific entries in the logfiles. (Only Server is listening on ....)
    OS: Deb Lenny 64Bit
    I'm running the Server on SQLite Support.
    Netstat:
    netstat -lnp | grep ts3
    tcp        0      0 0.0.0.0:30033           0.0.0.0:*               LISTEN      1633/ts3server_linu
    tcp        0      0 0.0.0.0:10011           0.0.0.0:*               LISTEN      1633/ts3server_linu
    udp        0      0 0.0.0.0:9000            0.0.0.0:*                           1633/ts3server_linu
    udp        0      0 0.0.0.0:9002            0.0.0.0:*                           1633/ts3server_linu
    udp        0      0 0.0.0.0:9005            0.0.0.0:*                           1633/ts3server_linu
    udp        0      0 0.0.0.0:9006            0.0.0.0:*                           1633/ts3server_linu
    udp        0      0 0.0.0.0:9008            0.0.0.0:*                           1633/ts3server_linu
    udp        0      0 0.0.0.0:9009            0.0.0.0:*                           1633/ts3server_linu
    udp        0      0 0.0.0.0:9010            0.0.0.0:*                           1633/ts3server_linu
    udp        0      0 0.0.0.0:9011            0.0.0.0:*                           1633/ts3server_linu
    I've been trying to find a Solution to this particular Problem for a few Days now. Unfortunate I had no Luck til now. Obviously there are many other TS Users which have the same Problem as I do.
    I'be be grateful for any Help , Input and Solutions
    Sincerly XTrian
    December 2011
    6
    I have the same Problem on Open SUSE 11.4 Linux -.-
    We had to make the Server new because i lost the Serveradmin PW.
    Since this we have Problems!
    Hope we gonna fix it!
    December 2011
    i didnt change anything on my Ubuntu 10.04 Server. It happen yesterday after a 6th person connects. Somebody randomly disconnects after some seconds - connection lost.
    Greetings
    UK
    768
    I'm sure this isn't the problem but have you checked that you're actually allowing more than five people to log in to each channel at a time?
    December 2011
    6
    I tested it:
    I set the Limit to 16 per Channel or Unlimited all things the same after 5 or 6 Users the server randomly kicks someone (connection lost).
    But:
    On my emergency Home Server under Windows XP (32 bit) Working without problems!
    We need our Master server !!!
    UK
    768
    I guess there's no bandwidth issues which would mean that users were being kicked off when too many users are connected. Highly unlikely I know, but worth looking at.
    November 2011
    I full agree Air SeaTac, that couldnt be a bandwidth issue. Our TS-Server have a connection with a bandwidth up to 100mbit in/out and we haven´t detected any paketloss or high ping rates. Strange ....
    I wrote a Ticket to the Support (ATHP) a few days ago but i haven't received any helpful response yet. Maybe this is a known issue and not easy to fix?! We will see
    December 2011
    6
    Humm...
    Bad
    Hope they fix it fast...
    I can run our Server unter Windows without problems but Linux .......heh...
    December 2011
    we have the same problem on our server with ubunto 10.0
    has anyone had a solution to the problem
    sry for my english this is translate with google
    November 2011
    The TS-Support told me this should be a Licensing issue. This happens when Port 2008 is closed / unreachable from "accounting.teamspeak.com". Next issue --> This Port is open on tcp + udp. The TS-Support gets root-access to my Teamspeak-Server but i have no response this time.
    I´ll tell later in this thread if they found the issue and a solution.
    December 2011
    Lübeck , GErmany
    I have the same problem. The Idle Time I've already set to -1, server and set up again, same problem. Is there now a solution to the problem already?
    December 2011
    And I have exactly the same problems. If more than 5 users connected to my Ts3 Server we getting dropped connection lost. My server is a VServer with CentOS 6 64Bit with Plesk 10. The Ports 2008, 9987, 10011 an 30033 are open. I have no ideas what's going wrong? I have several times the Server deinstalled and installed but no "improvement" to see.
    Sorry for my englisch. and greetings from Germany.
    exo
    November 2011
    The Support gets root-data on December 20th. On December 23rd the last reply was:
    Thanks, i will look into it and get back to you.
    In the Console i saw that the Support was connected on 23rd. (I won't write what the comandline-History shows) Anyways today we do have December 29th?! I´m considering our Company shall cancel the ATHP-License and / or be refunded for the Periode of time TS3 has not been working properly.
    December 2011
    Hi, is there any solution yet?
    I still having the problems with more then 5 people on the ts. I have created a second virtual server, got the same problem. But it is possible to have on each virtual server 5 people. If the 6th joins, someone randomly disconnects.
    Greetings
    December 2011
    We have time to NEN 2nd root tried with multiple operating systems
    among other debian suse 11.0/11.4 5.0/6.0 open fedora11/13/15 and ubunto10.04/11.04
    yet we always have the same problem
    sorry for my english it is translate with google
  1. Replies: 1
    Last Post: November 9th, 2013, 12:36 PM
  2. Replies: 2
    Last Post: October 31st, 2013, 11:26 PM
  3. Replies: 1
    Last Post: July 2nd, 2011, 10:24 PM
  4. Replies: 5
    Last Post: June 30th, 2011, 12:51 AM
  5. [No Bug] Updated to "Beta Channel" version, reverted, "lost" my contacts
    By Nev0r in forum Client Support
    Last Post: March 21st, 2011, 02:02 PM
