Results 1 to 11 of 11
    December 2011
    6
    Solved Port open, but doesn't work
    Hey guys im having trouble setting up a Teamspeak 3 Server i have this hub
    BT Home Hub V3
    http://www.tvanswers.org.uk/images/bthomehub.jpg
    and when i go to add ports on my router options it has this...
    Hub Options
    http://img249.imageshack.us/img249/1...huboptions.jpg
    And these are my options
    Updated Options
    http://img853.imageshack.us/img853/7...edsettings.jpg
    And when i go on teamspeak and connect to my IP: **.***.***.**:9987
    it just says:
    <18:58:24>Trying to connect to server on **.***.***.**
    <18:58:30>Failed to connect to server
    Please Help If somebody could do teamviewer and set it up for me i would be so gratefull thanks <33
    Catalunya
    2,350
    Set:
    9987 UDP (only)
    10011 TCP
    30033 TCP
    And if still, you can't connect, gives us more information, see this post:
    http://forum.teamspeak.com/showthrea...of-information.
    December 2011
    6
    Thanks for the reply i just updated my ports and when i connect to 81.156.183.90:9987 it just says "Error" in a voice
    Pitt
    103
    You just created a service. You need to actually apply it to an IP/Host. Probably under configuration or firewall.
    December 2011
    6
    i have heres a pic
    http://img35.imageshack.us/img35/4293/configc.jpg
    can we teamviewer? so u can help me out? :L
    --- Merged ---
    Oh and port checker says this when i try UDP > 9987
    http://img846.imageshack.us/img846/6374/portchecker.jpg
    February 2008
    Germany, Schorndorf
    186
    Hi ImACookie,
    do you have a Firewall on your Server. If yes pls check that TS3 traffic is allowed
    December 2011
    6
    Sorry i don't know how to find that out :L do you mean windows firewall? If so it is allowed on windows firewall
    May 2010
    6,310
    Don't forget on almost every router, you can't use your External IP from your Internal network.
    Are you able to connect with the 127.0.0.1 IP or with the local IP ?
    Yes Dabulator talk about your Windows firewall. But for test turn off it (also your anti-virus if you have).
    About your router, this web page can help you to be sure that you have correctly set your router : http://www.filesaveas.com/bthomehub_portforwarding.html
    December 2011
    6
    yes i can connect using 127.0.0.1 and ok what ip do i give my friends to join? my ip in this format
    **.***.***.**:9987 or **.***.***.**
    yes i cut the ip out :L
    oh and by the way my hub doesn't have the "Trigger Protocal" Option it was removed in the BT Home Hub V3
    May 2010
    6,310
    With the default port (9987) you just can give your External IP.
    (Don't forget, if you have dynamic IP you have to check it several times)
    December 2011
    6
    fixed thankyou everybody for your help <3
  1. Voice port doesn't work.
    By Weraten in forum Server Support
    Last Post: July 31st, 2015, 09:43 AM
  2. I Port forwaded My router and server still doesn't work??
    By DaniSerb in forum Server Support
    Last Post: October 27th, 2013, 08:41 AM
  3. Replies: 3
    Last Post: February 25th, 2011, 05:10 PM
  4. Replies: 0
    Last Post: February 24th, 2011, 09:39 PM
