Results 1 to 2 of 2
Thread: TS3 Sound
    December 2011
    Solved TS3 Sound
    Hey Community
    thats my first post in this forum...
    i've got a little problem with my soundpacks
    here the error log:
    27.12.2011 22:50:29	ClientUI	Warning	Did not find notification for ID XXXXX
    27.12.2011 22:50:29	ClientUI	Warning	Could not find notification ID (get text location) XXXXX
    So i can't hear any sound while switching channels or what ever.. but if i go to the Options -> Notifications, select any sound (doesn't matter which soundpack) and play the demo of it it works.
    So my big question is: how can i fix it? ^^
    I already try:
    • reinstallation
    • cleaning temp files
    • reboot
    • and so on^^
    doesn't work
    Thanks for help
    OK I've solved the problem...
    This is the way to do it:
    change the name of the soundpay directory, then change the default soundpack in notification.
    If you have got bookmarks u should edit the bookmarks.ini in %appdata%\TS3Client
    replace the old dir. name of the soundpack with the now one for each "SoundPack=" value and u'll be done^^
    March 2012
    TS3 - Notification Sounds Bugged (Vista 32-bit)
    Hi, I've been using TS3 for the past two years and then suddenly this bug appears where all of the notification sounds are not playing. (Eg: Disconnected, Connected, User joined your channel, and etc)
    I have checked my notifications in options and all are enabled, I can hear voices of other people therefore the program itself is not muted. I can also hear the preview in the options menu when I click "Play".
    Any help would be appreciated.
    Snippet of Error log:
    3/20/2012 4:00:18 PM	ClientUI	Warning	Could not find notification ID (get text location) 17953
    3/20/2012 4:00:36 PM	ClientUI	Warning	Did not find notification for ID 16657
    3/20/2012 4:00:36 PM	ClientUI	Warning	Could not find notification ID (get text location) 16657
    3/20/2012 4:00:48 PM	ClientUI	Warning	Did not find notification for ID 16689
    3/20/2012 4:00:48 PM	ClientUI	Warning	Could not find notification ID (get text location) 16689
    3/20/2012 4:01:13 PM	ClientUI	Warning	Did not find notification for ID 16657
    *** Thread Merged ***
  1. Replies: 0
    Last Post: August 23rd, 2015, 02:33 AM
  2. Replies: 2
    Last Post: July 3rd, 2014, 09:40 AM
  3. Replies: 1
    Last Post: May 30th, 2013, 09:29 PM
