Results 1 to 2 of 2
    February 2005
    19
    Question Audioredirect with JACK
    Greetings everyone!
    Well... Old Story.. New Guy...
    I wanna make a musicbot for TeamSpeak. On Windows it is very simple.. Just install VAC, configure 2 cables and make the App using the cables...
    But on linux? I want it to run on my dedicated root server so...
    Do i need to load the kernelmodule for the soundcard?
    Do i need ALSA?
    Can anyone give me a tutorial for Jack?
    After 5 hours of experiments, currently virtualbox is runnin on the server with XP... But it is a Intel Atom with 1.6Ghz so die CPU Load keeps near 100%... The sound stutters...
    Please guys... How can i make it directly without virtualbox?
    February 2013
    If you have pulsaudio in your system (you didn't provide any info):
    Set TS to use Pulseaudio as source.
    Install pavucontrol.
    Start ts and pavucontrol.
    Connect to a server in TS.
    in pavucontrol go to "Recording" tab.
    There should be an entry for TS3, and a button labeled with your default mic.
    Click that button and select the "Monitor of" entry with your audio device.
  1. Problems with Jack via ALSA
    By shantho in forum Linux
    Last Post: April 22nd, 2014, 04:28 PM
