Results 1 to 5 of 5
    January 2012
    6
    Question Teamspeak 2 is using the mysterious port "35898" for unknown reasons?
    I have on my root a TS2 and a TS3 server running, both servers are working fortunately without problems. I check my server logs regularly and noticed that my firewall (CSF) is blocking a few connections of the TS2 server, here are the related log entries:
    Jan 11 17:17:52 Ubuntu-1004-lucid-64-minimal kernel: [173855.535415] Firewall: *UDP_OUT Blocked* IN= OUT=eth0 SRC=176.9.xxx.xxx DST=62.146.xxx.xxx LEN=431 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=8767 DPT=45647 LEN=411
    Jan 11 17:17:52 Ubuntu-1004-lucid-64-minimal kernel: [173855.536162] Firewall: *UDP_OUT Blocked* IN= OUT=eth0 SRC=176.9.xxx.xxx DST=62.146.xxx.xxx LEN=431 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=35898 DPT=45647 LEN=411
    Jan 11 17:22:52 Ubuntu-1004-lucid-64-minimal kernel: [174155.330036] Firewall: *UDP_OUT Blocked* IN= OUT=eth0 SRC=176.9.xxx.xxx DST=62.146.xxx.xxx LEN=431 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=8767 DPT=45647 LEN=411
    Jan 11 17:22:52 Ubuntu-1004-lucid-64-minimal kernel: [174155.330819] Firewall: *UDP_OUT Blocked* IN= OUT=eth0 SRC=176.9.xxx.xxx DST=62.146.xxx.xxx LEN=431 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=35898 DPT=45647 LEN=411
    Jan 11 17:27:52 Ubuntu-1004-lucid-64-minimal kernel: [174455.119435] Firewall: *UDP_OUT Blocked* IN= OUT=eth0 SRC=176.9.xxx.xxx DST=62.146.xxx.xxx LEN=431 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=8767 DPT=45647 LEN=411
    Jan 11 17:27:52 Ubuntu-1004-lucid-64-minimal kernel: [174455.120191] Firewall: *UDP_OUT Blocked* IN= OUT=eth0 SRC=176.9.xxx.xxx DST=62.146.xxx.xxx LEN=431 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=35898 DPT=45647 LEN=411
    Jan 11 17:32:52 Ubuntu-1004-lucid-64-minimal kernel: [174754.907898] Firewall: *UDP_OUT Blocked* IN= OUT=eth0 SRC=176.9.xxx.xxx DST=62.146.xxx.xxx LEN=431 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=8767 DPT=45647 LEN=411
    Jan 11 17:32:52 Ubuntu-1004-lucid-64-minimal kernel: [174754.908661] Firewall: *UDP_OUT Blocked* IN= OUT=eth0 SRC=176.9.xxx.xxx DST=62.146.xxx.xxx LEN=431 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=35898 DPT=45647 LEN=411
    udp        0      0 176.9.xxx.xxx:35898      0.0.0.0:*   4409/server_linux
    Port 8767 is opened in the firewall (CSF) and port 35898 is closed, I don't understand though why port 8767 is also being blocked sometimes by CSF and I don't get the purpose of port 35898.
    January 2012
    6
    I just saw in the other thread that 62.146.63.84 is the IP for accounting.teamspeak.com, my TS2 is trying to connect to 62.146.63.82 all the time which seems to be a very similar address. Is it possible that my TS2 server is trying to contact the main server of Teamspeak for some reason?
    January 2012
    6
    Nobody has an idea? Maybe someone from the Teamspeak staff could ask one of the TS2 developers?
    18,231
    They have no idea about this port. sorry.
    January 2012
    6
    Strange, especially because it is connecting to a Teamspeak master-server. Thank you for the reply.
  1. Replies: 1
    Last Post: March 30th, 2015, 04:22 PM
  2. Server Query Admin Kicked by "Unknown from IP:PORT"
    By otdto in forum Permission System
    Last Post: March 25th, 2013, 02:24 PM
  3. "Unknown from IP:PORT" - ???
    By tmalek in forum Server Support
    Last Post: August 25th, 2012, 12:42 PM
