Results 1 to 10 of 10
    January 2012
    Connection Issues
    i went out of town and my ts server was working fine and when i get back i can't connect. someone said while i was gone it was going online / offline.
    1/18/2012 3:05:46 PM Info Blacklist server resolved
    1/18/2012 3:05:46 PM Info Data sent to blacklist server
    1/18/2012 3:05:46 PM ClientUI Info Connect status: Connecting
    1/18/2012 3:05:47 PM Info Data received from blacklist server: 1,
    1/18/2012 3:05:52 PM ClientUI Info Connect status: Disconnected
    1/18/2012 3:05:52 PM ClientUI Info Failed to connect to server, want autoreconnect = 0
    1/18/2012 4:14:25 PM ClientUI Info Connect to server: 173.71.12.6
    1/18/2012 4:14:25 PM ClientUI Info Checking blacklist
    1/18/2012 4:14:25 PM Info Trying to resolve blacklist server
    1/18/2012 4:14:25 PM ClientUI Info Blacklist check ok
    1/18/2012 4:14:25 PM ClientUI Info Initiating connection: 173.71.12.6:9987 173.71.12.6
    1/18/2012 4:14:25 PM ClientUI Info Connect status: Connecting
    1/18/2012 4:14:25 PM Info Blacklist server resolved
    1/18/2012 4:14:25 PM Info Data sent to blacklist server
    1/18/2012 4:14:25 PM Info Data received from blacklist server: 1,
    1/18/2012 4:14:30 PM ClientUI Info Connect status: Disconnected
    1/18/2012 4:14:30 PM ClientUI Info Failed to connect to server, want autoreconnect = 0
    1/18/2012 4:17:56 PM ClientUI Info Connect to server: 173.71.12.6
    1/18/2012 4:17:56 PM ClientUI Info Checking blacklist
    1/18/2012 4:17:56 PM Info Trying to resolve blacklist server
    1/18/2012 4:17:56 PM ClientUI Info Blacklist check ok
    1/18/2012 4:17:56 PM ClientUI Info Initiating connection: 173.71.12.6:9987 173.71.12.6
    1/18/2012 4:17:56 PM Info Blacklist server resolved
    1/18/2012 4:17:56 PM Info Data sent to blacklist server
    1/18/2012 4:17:56 PM ClientUI Info Connect status: Connecting
    1/18/2012 4:17:56 PM Info Data received from blacklist server: 1,
    1/18/2012 4:18:02 PM ClientUI Info Connect status: Disconnected
    1/18/2012 4:18:02 PM ClientUI Info Failed to connect to server, want autoreconnect = 0
    1/18/2012 4:22:24 PM ClientUI Info Connect to server: 173.71.12.6
    1/18/2012 4:22:24 PM ClientUI Info Checking blacklist
    1/18/2012 4:22:24 PM Info Trying to resolve blacklist server
    1/18/2012 4:22:24 PM ClientUI Info Blacklist check ok
    1/18/2012 4:22:24 PM ClientUI Info Initiating connection: 173.71.12.6:9987 173.71.12.6
    1/18/2012 4:22:24 PM Info Blacklist server resolved
    1/18/2012 4:22:24 PM Info Data sent to blacklist server
    1/18/2012 4:22:24 PM ClientUI Info Connect status: Connecting
    1/18/2012 4:22:25 PM Info Data received from blacklist server: 1,
    1/18/2012 4:22:30 PM ClientUI Info Connect status: Disconnected
    1/18/2012 4:22:30 PM ClientUI Info Failed to connect to server, want autoreconnect = 0
    May 2010
    6,310
    I can't connect too. Please make sure this server is reachable (and started).
    January 2012
    i've started the server but can't connect to it
    i'm guessing it's an isp issue?
    May 2010
    6,310
    Where is this server ?
    If you are the owner do you get an error message in the server log ?
    January 2012
    i've only launched the server, i can't connect to it so i can't check the server log
    the server is next to me on a spare PC
    May 2010
    6,310
    Quote Originally Posted by phrozen_ View Post
    Can you connect with the local IP ?
    The forward rules are ok ?
    Ok so on the other pc go on server folder and check the log.
    January 2012
    i can connect with local IP and forward rules are ok
    you can see it on server list "peepeepounders"
    i should still be able to connect to my own IP without port forwarding shouldn't i?
    also i'm not really sure what i'm supposed to be looking for in the logs
    May 2010
    6,310
    Yes I see 2 users on this server (on server list) but still can't connect.
    A forward port is requered (or trigger if there is on your router).
    Also, check the firewall/anti-virus.
    Any strange or error message
    But if you can connect with the local IP, I guess there is no error.
    January 2012
    http://i40.tinypic.com/1zns9lj.jpg
    i don't see any error messages
    May 2010
    6,310
    Also check the Port triggering.
    There others ports (10011 - 30033) are not reachable too.
    If this router use range port try with 9986-9988 instead 9987-9988
  1. IP / Connection Issues
    By Tek_NSA in forum Windows
    Last Post: August 8th, 2015, 11:55 PM
  2. Need help with connection issues.
    By Evolution16 in forum Server Support
    Last Post: May 5th, 2012, 07:37 PM
  3. Connection Issues !Help!
    By Markd790 in forum Windows
    Last Post: September 25th, 2011, 10:21 AM
