Results 1 to 7 of 7
    January 2012
    Solved Connection error to localhost
    Hi!
    I, total Newbie in terms of Teamspeak, downloaded client and server software for TS3, ran the server-exe and tried to connect to localhost which did nothing. Same problem with either 127.0.0.1, my WAN and my LAN IP. The server should be up and running, but I cannot enter it. In Windows Firewall, I created permission for both client and server plus for UDP 9987 and TPC 30033 (as suggested by the tutorial video) and still have the same result.
    Win 7 Home Premium, 64 bit; server version 17.10.2011; client version 3.0.3
    I can login into other servers, so I guess it's no client problem...
    I hope I read all threads/FAQ concerning the topic so I won't be hated by everyone and am willing to provide more information if needed. =)
    Have a nice day!
    18,507
    Please check and provide soem server logs.
    Also make sure that you can reach your own local ip with any other tool.
    January 2012
    If it's enough to check the ping on my WAN by cmd.exe: That works. Otherwise please specificate an option to check.
    The following are the first 4 server logs and the latest one which is similar to all logs in between.
    ts3server_2012-01-24__15_28_25.206024_0.log
    ts3server_2012-01-24__15_28_25.206024_1.log
    ts3server_2012-01-24__16_16_23.535655_0.log
    ts3server_2012-01-24__16_16_46.944994_0.log
    ts3server_2012-01-25__13_30_00.318688_0.log
    edit: I will have the server running the next few hours, if you want to check yourself being able to log in.
    18,507
    Your server is not running.
    It crashed..
    2012-01-24 16:18:16.760131|INFO |VirtualServer | 1| stopped
    2012-01-24 16:16:24.078686|ERROR |Accounting | | local accounting reports an already running instance, instance will shutdown
    2012-01-24 16:16:24.078686|ERROR |ServerLibPriv | | Server() error while starting servermanager, error: instance limit reached
    2012-01-25 13:30:00.373691|ERROR |DatabaseQuery | | db_exec failed unable to open database file
    2012-01-25 13:30:00.373691|ERROR |DatabaseQuery | | db_exec() delete from instance_properties where string_id = '' ; error: unable to open database file
    2012-01-25 13:30:00.373691|ERROR |ServerLibPriv | | Server() error while starting servermanager, error: database error
    January 2012
    Well, thanks for the info. Can I do something about it? Delete the server files and download new? Repair it somehow?
    18,507
    http://forum.teamspeak.com/showthrea...Client-Command
    This thread gives answer about your problem.
    January 2012
    I don't really see a solution in that thread, but as deleting all files and redownloading the server helped, I sincerely thank you for the time spent with my problem.
  1. Replies: 1
    Last Post: November 6th, 2014, 04:10 PM
  2. No connection to Localhost or 127.0.0.1
    By frankbackes in forum Windows
    Last Post: June 13th, 2014, 07:55 PM
  3. Replies: 11
    Last Post: January 1st, 2010, 12:34 AM
