Results 1 to 2 of 2
Thread: Privilege key
    February 2012
    Privilege key
    Hi there,
    I`m having a problem filling the correct Privilege key.
    When i connect to my new virtual server it will ask for my privilege key.
    I`ve copied the privilege key from the query to my clipboard and pasted it.
    This key must be the only key i have. Still it tells me that this key is not correct or allreadyi n use.
    I`ve tried to setup a new virtual server,
    this time the admin query tells me my new login and password but the privilige key isn`t showing. Tried this several times now neither of all attempts will give me the key.
    What to do now because i cant manage the new virtual server.
    Kind regards,
    Johan de Heer
    May 2010
    6,310
    If the privilege key is not showed, there seems you had started a second Teamspeak Instance instead create a second virtual server.
    In this case all ports are already used by your first instance.
    And I guess you haven't a NPL license to start another virtual server.
    Nervemind.
    Are you 100% positive that you copy the entire key ?
    Do you try to create another key with the query command (tokenadd) ?
    You could try to remove the database to start like a fresh install.
  1. Privilege Key Help Please!
    By Bossnix in forum Windows
    Last Post: October 26th, 2013, 07:52 AM
  2. use privilege key
    By ByeBye in forum Linux / FreeBSD
    Last Post: March 13th, 2013, 01:04 PM
  3. privilege key used
    By BL3ND in forum Linux / FreeBSD
    Last Post: August 14th, 2012, 03:32 PM
  4. [Resolved] Privilege Key
    By coreyman in forum General Questions
    Last Post: June 27th, 2011, 01:51 AM
  5. ts3 privilege key
    By icmerse08 in forum General Questions
    Last Post: February 11th, 2011, 03:26 AM
