Results 1 to 9 of 9
    February 2012
    18
    Solved ServerQuery - "Open Connection" and "Banned" message issues
    Note: Please move this to the correct forum if it is in the wrong place. Also, I didn't see any other threads addressing this. Please link me if it has been.
    I've been running across this problem for quite a while and just now got around to troubleshooting it. When you are banned from the Teamspeak Query server for sending messages too fast, the banned message is sent without an "\n\r" appended to the end, contrary to all other messages sent to the user. This causes an issue where I can't tell if the response has been fully received or not, usually causing my program to hang indefinitely.
    As for connecting to the server, normally a "error id=0 msg=ok" is not sent upon connection. However, if you are banned for flooding, then an "error id=#### msg=you are banned for x seconds" is sent immediately after the Teamspeak server's welcome message, also without an "\n\r". This also causes problematic behavior, as it causes the banned message to go unnoticed, as we are not normally expecting an error message to be received at this time.
    I've only been able to work around this issue by purposefully delaying my program upon establishing a connection to see if an error message is sent, as well as hard-coding the entire error message, to make sure I have received the entire response.
    Sincerely,
    -Imisnew2
    *** Thread Merged ***
    I guess this belongs into the server section.
    You are talking your program hangs? What program does hang? And can you give us an how to reproduce?
    What do you use, to login into the query? Is it the ServerQuery under tools or putty/telnet?
    I connect to Teamspeak using my own program, via C#. If I try to connect with PuTTY while I'm banned, PuTTY immediately closes after establishing a connection. These are the two messages sent when trying to connect to my Teamspeak server. One while I'm banned, the other while I'm not.
    Not Banned:
    TS3\n\rWelcome to the TeamSpeak 3 ServerQuery interface, type "help" for a list of commands and "help <command>" for information on a specific command.\n\r
    Banned:
    TS3\n\rWelcome to the TeamSpeak 3 ServerQuery interface, type "help" for a list of commands and "help <command>" for information on a specific command.\n\rerror id=3329 msg=connection\sfailed,\syou\sare\sbanned extra_msg=you\smay\sretry\sin\s221\sseconds
    Note, the lack of a \n\r on the end of the message (I haven't poked around, but It seems to be missing \0 as well, because the socket never times out when trying to receive the rest of the message, instead it returns '0 bytes received' and loops indefinitely).
    I can post the code that will allow you to re-create the issue upon request.
    --- Merged ---
    I'm unsure if my post got eaten, as this is my first time on the Teamspeak 3 Forums, but I'll re-iterate what I posted earlier.
    "Banned" message issue:
    The program I am talking about is my own program. It connects to the server query back-end and sends/receives commands fairly quickly. Whenever a "you are banned" message is received, it does not have \n\r\0 attached to the end of the packet, and thus causes the socket to believe there is still more to the packet. Moreover, without the \n\r marker, it's hard to determine when the message ends. This is what I mean:
    error id=3331 msg=flood\sban
    error id=3329 msg=connection\sfailed,\syou\sare\sbanned extra_msg=you\smay\sretry\sin\s538\sseconds
    Note, these do NOT have the traditional \n\r\0 on the end, like other responses (note, the \0 is stripped off by the socket):
    error id=0 msg=ok\n\r
    This causes two issues:
    - The socket does not know that it has reached the end of the packet (due to the lack of \0), and never times out on "Receives."
    - The end of the message is unable to be determined (due to the lack of \n\r), and loops indefinitely waiting for the rest of the message.
    "Open Connection" message issue:
    Moreover, when attempting to open a connection while you are banned results in an error message being sent directly after the connection is opened. This causes us to attempt to send information to the server after the connection has been closed, as normally, an error message is not sent after the connection is opened. This is what I mean:
    TS3\n\rWelcome to the TeamSpeak 3 ServerQuery interface, type "help" for a list of commands and "help <command>" for information on a specific command.\n\rerror id=3329 msg=connection\sfailed,\syou\sare\sbanned extra_msg=you\smay\sretry\sin\s538\sseconds
    Edit:
    This was tested on both Server Version 3.0.0-rc1 (Windows) and 3.0.1 (Windows).
    Sincerely,
    -Imisnew2
    Is this forum the correct way to submit bug reports like these? If not, could someone please give me the correct procedure?
    18,513
    18,513
    I can not follow your report :-/ where is your problem?
    I don't see any error in our message. the last \n\r sets a new line not all telnet programs, do that by default.
    Sorry about merging post #1. 2 different Threads got merged.
    February 2012
    18
    \n\r\0 do not exist on the end of banned messages. The lack of \0 causes the socket to not time-out, because it still thinks the packet has not been finished. The lack of \n\r is not as important, but it is included on the end of every other message, causing confusion when it is not there for 2 messages out of thousands(?). The unexpected appearance of an error message after opening a connection also causes confusion, which could be avoided by making an error message sent after opening a connection standard procedure.
    There are three issues there.
    252
    Ok we figured out what your problem is :P
    Thank you for your help.
    InternalTicketID: TS-869
    February 2012
    18
    Quote Originally Posted by MuhChy View Post
    Thank you MuhChy.
    If you need anymore information, please let me know. I'm pretty much knee-deep dealing with the Teamspeak Server Query back-end at the moment, so I've got plenty of responses floating around. Great work on the Server Query stuff, however, the rest is working without an issue!
    252
    - Your problem should be fixed with serverversion (Feb 21th and newer).
    It would be nice if you could retest your problem when the serverversion becomes available.
    February 2012
    18
    Thank you. Should the 3.0.2 release contain the fix, or will it be included in 3.0.3 pre-release?
    18,513
    This will be fixed in our Server 3.0.2
  1. Replies: 2
    Last Post: July 8th, 2015, 10:39 AM
  2. Please Update this Plugin ""Connection History"" Or Include to Client Version
    By varela1george in forum Suggestions and Feedback
    Last Post: October 13th, 2012, 07:28 AM
  3. Can I use "whisper" to enable a "Public" and "Private" channel?
    By DadisAjax in forum General Questions
    Last Post: June 28th, 2012, 11:59 PM
  4. [On Todo] ServerQuery - "Open Connection" and "Banned" message issues
    By Imisnew2 in forum Server Support
    Last Post: February 18th, 2012, 04:24 PM
  5. Replies: 0
    Last Post: December 23rd, 2009, 08:49 PM
