Results 1 to 6 of 6
    Düsseldorf
    6
    TS3 and fsockopen
    I have an Problem.
    The clear fsockopen command is that here:
    $fp = fsockopen("ip","port",$errno,$errstr,2);
        if(!$fp)
                echo 'Offline';
            }else{
                echo'Online';
    @fclose($fp);
    edit:/
    Error:
    Warning: fsockopen() [function.fsockopen]: unable to connect to xxx.x.xxxx.xxx:9987 (Connection refused) in /var/www/index.php on line 7
    Lg.
    Actros
    May 2010
    6,310
    You try to connect to the voice port (on a virtual server), this is the error.
    I guess you want to connect on the Query port and it's the 10011 port (by default)
    Düsseldorf
    6
    no i need the voice ports
    when one of the servers are offline i need to display that.
    May 2010
    6,310
    You can't by the voice port.
    This is not how the system works. On the voice port the server wait for client connection.
    You have to use the query command ("on the query port") to check if a vitual server is online are not (serverlist or serverinfo)
    You have some old script on this forum and some librairies/tool on the addons website.
    Düsseldorf
    6
    So must i go over the Server Query port and look there is Serverid 1 2 3 and so on are online?
    May 2010
    6,310
    Effectively
  1. Problem with fsockopen()?
    By cddude in forum Windows
    Last Post: May 31st, 2014, 10:26 PM
