Page 2 of 5 FirstFirst 1234 ... LastLast
Results 16 to 30 of 75
  1. #16
    January 2016
    As I repeat over and over again.
    No Grant Value = You can not assign, remove or change target permissions.
    I do not see any Grant value on the desired permissions set in your Screenshot.
    Please read post #13 for an example
    I'm sorry for asking this but is there any chance you could go a little bit more in depth, if possible maybe with a screenshot (Or my screenshot edited explaining what exactly has to be edited.) I am just quite lost here at the moment. It was this post I was talking about by the way, where I've been trying all solutions provided in this topic, I guess I am doing something wrong but I can't seem to figure out what. I've been trying to work with both grant, normal permissions. I am just really lost here. Sorry for asking so much of you but it'd really help us out.
  2. #17
    18,513
    There is no Grant set.
    Green is good and red is missing.
  3. #18
    January 2016
    After editing it I am sadly still getting the Insufficient permission modify power. I've followed what you've stated above, given the proper grant permissions, as described in the picture provided to you, yet still no luck sadly.
  4. #19
    18,513
    Please show us a permission overview and tell us which group you want to allow to edit channel permisions. I'm giving up to answer to these screenshots showing nothing about the permission situaution.
    Do not show a screenshot of the permission dialog. I want a full permission overview which can be created via right-click on a user.
  5. #20
    January 2016
    This is the group I've been actively trying to set this up for. Again I'd like to thank you for your time, I know I am a pain in the ass at the moment.
    Server Groups
    	Senior Administrator
    		ServerQuery: View Virtual Server Info 1 0 0
    		View Virtual Server Connection Info 1 0 0
    		ServerQuery: View List of existing Channels 1 0 0
    		ServerQuery: View List of Clients online 1 0 0
    		Use Privilege Keys to gain permissions 1 0 0
    		Channel Max Depth -1 0 0
    		Stop Channel Group Inheritance 1 0 0
    		Channel Permission Modify Power 75 1 0
    		Needed Channel Permission Modify Power    75
    		ServerQuery: View Channel Info 1 0 0
    		Create Sub-Channels 1 0 0
    		Create Permanent Channels 1 0 0
    		Create Semi-Permanent Channels 1 0 0
    		Create Temporary Channels 1 0 0
    		Create Private Channels 1 0 0
    		Create Channels with Topic 1 0 0
    		Create Channels with Description 1 0 0
    		Create Channels with Password 1 0 0
    		Create Channels with Speex Narrowband Codec 1 0 0
    		Create Channels with Speex Wideband Codec 1 0 0
    		Create Channels with Speex Ultra-Wideband Codec 1 0 0
    		Create Channels with CELT Mono Codec 1 0 0
    		Create Channels with Opus Voice Codec 1 0 0
    		Create Channels with Opus Music Codec 1 0 0
    		Create Channels with Max Codec Quality 10 0 0
    		Create Channel with Minimum Latency Factor 10 0 0
    		Create Channels with Max Clients 1 0 0
    		Create Channels with Max Family Clients 1 0 0
    		Create Channels with Sort Order 1 0 0
    		Create Channels with Needed Talk Power 1 0 0
    		Temporary channel delete delay 600 0 0
    		Move Channels 1 0 0
    		Change Channel Type to Permanent 1 0 0
    		Change Channel Type to Semi-Permanent 1 0 0
    		Change Channel Type to Temporary 1 0 0
    		Modify Channel Name 1 0 0
    		Modify Channel Topic 1 0 0
    		Modify Channel Description 1 0 0
    		Modify Channel Password 1 0 0
    		Modify Channel Codec 1 0 0
    		Modify Channel Codec Quality 1 0 0
    		Modify Channel Latency Factor 1 0 0
    		Modify Channel Max Clients 1 0 0
    		Modify Channel Max Family Clients 1 0 0
    		Modify Channel Sort Order 1 0 0
    		Modify Channel Needed Talk Power 1 0 0
    		Channel Modify Power 75 1 0
    		Needed Channel Modify Power    75
    		Modify Channel Voice Encryption 1 0 0
    		Delete Permanent Channels 1 0 0
    		Delete Semi-Permanent Channels 1 0 0
    		Delete Temporary Channels 1 0 0
    		Channel Delete Power 75 0 0 75
    		Needed Channel Delete Power    75
    		Join Permanent Channels 1 0 0
    		Join Semi-Permanent Channels 1 0 0
    		Join Temporary Channels 1 0 0
    		Ignore Channel Passwords 1 0 0
    		Ignore Channel Max Clients 1 0 0
    		Channel Join Power 75 0 0
    		Needed Channel Join Power    75
    		Channel Subscribe Power 75 0 0
    		Needed Channel Subscribe Power    75
    		Channel Description View Power 75 0 0
    		Needed Channel Description View Power    75
    		Icon ID 305276274 0 0
    		Group is Permanent 1 0 0
    		Group Auto Update Type 30 0 0
    		Group Sort ID 3 0 0
    		ServerQuery: View List of Server Groups 1 0 0
    		View List of Server Group Members 1 0 0
    		ServerQuery: View List of Channel Groups 1 0 0
    		View List of Channel Group Members 1 0 0
    		View List of Channel Permissions 1 0 0
    		Needed Group Modify Power 75 0 0
    		Group Member Add Power 20 0 0
    		Needed Group Member Add Power 30 0 0
    		Group Member Remove Power 20 0 0
    		Needed Group Member Remove Power 30 0 0
    		Max number of additional connections per Identity 10 0 0
    		Max Avatar Filesize (Bytes) 200000 0 0
    		Max Channel Subscriptions -1 0 0
    		Skip Channel Group Permissions 1 1 0 75
    		Ignore Anti-Flood Measurements 1 0 0
    		Use Channel Commander 1 0 0
    		Request talk power in moderated channels 1 0 0
    		Delete other clients avatar 1 0 0
    		ServerQuery: View Client Info 1 0 0
    		View Client Permission Overview 1 0 0
    		View Own Client Permission Overview 1 0 0
    		View Client Remote Address 1 0 0
    		Needed ServerQuery Client View Power 75 0 0
    		Client Kick From Server Power 20 0 0
    		Needed Client Kick From Server Power 25 0 0
    		Client Kick from Channel Power 20 0 0
    		Needed Client Kick from Channel Power 25 0 0
    		Client Ban From Server Power 20 0 0
    		Needed Client Ban Power 25 0 0
    		Client Move Power 20 0 0
    		Needed Client Move Power 10 0 0
    		Client Complain Power 50 0 0
    		Needed Client Complain Power 50 0 0
    		View List of Client Complaints 1 0 0
    		Delete all Complaints 1 0 0
    		View List of Ban Rules 1 0 0
    		Create new Ban Rules 1 0 0
    		Delete own Ban Rules 1 0 0
    		Delete all Ban Rules 1 0 0
    		Max Time for Ban Rules in seconds -1 0 0
    		Private Textmessage Power 50 0 0
    		Send Text Messages to Server 1 0 0
    		Send Text Messages to Channel 1 0 0
    		Send Text Messages to Offline Clients 1 0 0
    		Client Talk Power 65 0 0
    		Client Poke Power 50 0 0
    		Client Whisper Power 10 0 0
    		Needed Client Whisper Power 1 0 0
    		Modify all Client Descriptions 1 0 0
    		Modify own Client Description 1 0 0
    		File Upload Power 50 0 0
    		File Download Power 50 0 0
    		File Delete Power 50 0 0
    		File Rename Power 50 0 0
    		File Browse Power 50 0 0
    		Directory Create Power 50 0 0
    		Download Quota per Client (MByte) -1 0 0
    		Upload Quota per Client (MByte) -1 0 0
    	All
    		Move Channels 1 0 0
    		Group Sort ID 3 0 0
    Client
    Channel
    	Sparkie's Channel
    		Needed Channel Join Power 30
    		Needed Channel Subscribe Power 0
    		Icon ID -45323863
    Channel Groups
    	Guest
    		Group Auto Update Type 10
    Channel Client
    All
    	Move Channels 1 0 0
    	Group Sort ID 3 0 0
  6. #21
    January 2016
    Allow Admin to Change Modify Permission When Creating a Channel
    Hey I've been messing around with this issue for a few hours and I'm stumped.
    I created a lower level admin server group for my server, called it "Admin." I'm wanting to make it so that when Admins create a channel, they can edit the permission values in the "Regular Needed Powers" box to whatever value they want. Mainly, so they can set both "Modify" and "Delete" to their own power value (60), so only Admins can change or delete the channel.
    The problem I've been having is that changing the "Modify" permission results in an error message "insufficient permission modify power." The channel gets created, and the delete value is set properly to 60, but the modify value is set to 0. When I right click the channel and use "Edit Channel" to try to set the Modify value to 60, it results in the same error.
    I've been playing around changing things, and I found a way to force it to work. The Grant value of "i_channel_needed_modify_power" of the channel I created is default grayed out. By setting it to 60, then right clicking the channel, clicking Edit Channel, and setting the Modify permission value to 60, it works.
    What I don't understand is why that would be messing things up, when the "i_channel_needed_delete_power" Grant value for the channel is also grayed out, and yet it still lets me set that value when creating or editing the channel.
    Is there something I am missing?
    Thanks in advance!
    Last edited by dante696; January 29th, 2016 at 09:06 AM. Reason: merged, see next post.
  7. #22
    18,513
    @ Afterpwn
    Much better
    I think i have found what is missing here and i also did not think about it
    i_permission_modify_power (Permisison Modify Power) also needs to be enabled and set to 75.
    This example shows all needed permisisons to edit all channel permissions.
    Please note that 75 is not the best value, because these users can edit even channels created from the Server admin.
    You may use lower values here and/or add it to channel groups instead and not to a server group.
Name:	allow to edit channel permissions.png
    I hope this solved everything.
    @ EagleEye131
    Please check all permissions from my screenshot 2 (values of 75 are just an example).
Name:	allow to modify channel perms while in create dialog.png
  8. #23
    January 2016
    @ Afterpwn
    Much better
    Please note that 75 is not the best value, because these users can edit even channels created from the Server admin. You may use lower values here and/or add it to channel groups instead and not to a server group.
    You are an angel, thank you so much for your assistance, after months of bickering on this you finally helped me get a solution!
  9. #24
    April 2015
    38
    Unable to edit channel "Regular Needed Powers"
    I'm unable to edit Regular Needed Powers as Server Admin. But File Transfer Needed Powers work fine.
    Non of the permissions inside red isn't working but blue's are OK. How can I fix this ?
    I changed i_channel_modify_power and i_channel_permission_modify_power to 100 on Server Admin using Admin Server Query, didn't help. (Both were 75)
  10. #25
    18,513
    No Grant = you can not set these permissions.
    You do not have Grant on any of them.
    It's time to fix your Server Admin group like requested in your other thread!
    http://forum.teamspeak.com/threads/1...470#post426470
  11. #26
    April 2015
    38
    The thread on the link doesn't belongs to me.
    What do you mean no grant ? Basicly every permissions already have grant as its nature in Server Admin.
  12. #27
    18,513
    Quote Originally Posted by sunpeace View Post
    Nope, you don't have Grant on the permissions you need (and some more Grants are misising).
Name:	there is no grant.png
    Your Server Admin is messed up (compared to our default permisison layout).
    You may fix your Server Admin group as mentioned. You can't re-add the Grant values without the ServerQuery or another Group who owns the Grant + is able to modify your Aerver Admin group.
  13. #28
    March 2016
    Issues with Permissions
    I am having two issues with setting up permissions for groups.
    The first is that I am unable to set a group to be able to change channel permissions. I was wondering what the exact permissions where that affected this. Currently I have it set to:
    T = True or Checked
    F = False or Unchecked
    i_channel_modify_power [20] [F] [F] []
    i_channel_permission_modify_power [20] [F] [F] []
    i_channel_needed_permission_modify_power
    b_virtualserver_channel_permission_list [T] [F] [F] []
    The group is unable to edit any permissions listed under Edit Channel -> Permissions.
    Is there a way to set a default modify permission on a channel?
    I want that specific group to be able to set 20 on all channel permissions.
  14. #29
    July 2016
    Won't allow server group to change "Regular Needed Powers"
    I have been reading through the last few replies on the thread and looking at the screenshots.
    I followed everything you showed @dante696 but instead of putting 75 i put 70, it still says insufficient permissions when editing the channel's regular needed powers
    Can anyone help?
  15. #30
    18,513
    And i_channel_permission_modify_power is enabled and set to 70 for your group?
  1. [Resolved] Channel group / channel permissions affecting server group?
    By Amit86 in forum Permission System
    Last Post: February 1st, 2016, 07:46 AM
  2. Add user in channel group after he creates channel
    By Freakmeister in forum Permission System
    Last Post: September 1st, 2013, 11:29 PM
  3. Replies: 4
    Last Post: July 16th, 2012, 12:55 PM
  4. User with Group and Channel
    By Phoenyx77 in forum Permission System
    Last Post: August 29th, 2010, 10:11 AM
  5. Assign non-default channel group when user joins channel.
    By Morfi in forum Permission System
    Last Post: May 15th, 2010, 08:06 PM
