Page 4 of 5 FirstFirst ... 2345 LastLast
Results 46 to 60 of 75
  1. #46
    January 2014
    Server Moderator Editing Channels
    So I'm having an issue where I have a tag for server moderator and I want them to be able to edit channels. For the longest time, even when I had their i_channel_permission_modify_power set to 70 and i_channel_needed_permission_modify_power set to 70, I kept getting an error. I quickly realized that they couldn't edit channels because they didn't have i_permission_modify_power. I set their i_permission_modify_power to 70 and they still couldn't edit the channel (note that the channel itself in the modify category is 0.) Once I set their permissions up to 75, they could edit channels again like they were supposed to be able to, but then I noticed that they could edit channels that I did not want them to be able to edit (staff offices.) Their overview of permissions is in the picture below. I really need help figuring this out. I had the same issue with another lower moderator group and the easiest fix for them was to remove viewing channel permissions so they could not edit channels.
    http://puu.sh/sD65t/988590cb90.png
  2. #47
    18,513
    Why does this group has i_channel_needed_permission_modify_power assigned?
    This permission belongs into a channel only.
    I_permission_modify_power
    isn't needed in case they only should be able to edit channel permissions.
    See post #35 for an how to:
    http://forum.teamspeak.com/threads/7...el-permissions
  3. #48
    April 2017
    channel groups
    Hello, I am trying to make it so that a channel group is able to modify the channel permissions of the channel they are in. I have i_channel_modify_power set to 75 with grant 75 but they are unable to modify the channel permissions. The error msg when the user trys to change the permissions are: insufficient permission modify power
  4. #49
    18,513
    Your group needs more permissions to edit channel permissions.
    Please have a look at Post #35 for an example.
  5. #50
    April 2017
    I checked that out but it doesn't seem to be working. Am I missing something here? http://i.imgur.com/d7QR4kZ.png
  6. #51
    18,513
    I can not see a mistake, maybe the permissions are overwritten somewhere.
    Please show us a permission overview (right click on user -> permissions -> permissions overview -> then select "export as text"
    Hint: Please do not create another thread (with exact same content/topic). These will be handled as duplicate and removed from forum.
    Better post here again.
  7. #52
    April 2017
    I have attached the overview with the user haveing the guest server group and member server group, both being how the perms were tested.
    Attached Files Attached Files
  8. #53
    April 2017
    Any ideas?
  9. #54
    18,513
    Please add a 50 or 75 into the permission i_permission_modify_power. Leave Grant on that permission empty.
    This should do the trick. I better update the example.
    I was missing that :/
  10. #55
    April 2017
    Do I want to add i_permission_modify_power to the channel group or the server group?
    Edit: I tried to add i_permission_modify_power of 75 to both guest and my channel group and the user is still unable to modify the channel permissions. I will continue to test
    Edit2: After some testing the group will allow the user to edit the perms on a already created channel but not allow them to change them on creation. Slightly annoying but my members can deal with it for now.
    Edit3: So, they are able to edit the permissions now but I'm not able to limit how high they can set the permission.
  11. #56
    April 2017
    Channel permissions problem
    I want that an Admin rank can modify channel permissions similar to this: http://prntscr.com/f2x9ok
    Per example, an error that appear me is this: http://prnt.sc/f2x3az
    This is the permission on the server group: http://prnt.sc/f2x3ft
    And this is the channel permission section: http://prnt.sc/f2x3ll
    I need help pls!
  12. #57
    France
    10
    channel permission modify power
    I have a probleme with my server.
    I have a group "admin" with this value :
    70 for i_channel_permission_modify_power
    70 for i_channel_modify_power
    My channel have the value
    30 for i_channel_needed_permission_modify_power
    30 for i_channel_needed_modify_power
    And impossible to change the value for i_channel_needed_join_power
    I have error : Insufficient authorization modification power
    Why my group admin can't change value ? Where is my error ?
    Thank you
  13. #58
    France
    10
    If i activate b_permission_modify_power_ignore the group admin can change value.
    An idea of my problem ?
  14. #59
    December 2016
    32
    It could be many things... can you give us a copy of all permissions of an admin (right-click on an admin -> open permission overview -> then export as text)
    It could be a missing grant power for i_channel_needed_join_power or missing permission modify power...
    Never ever set this b_permission_modify_power_ignore permsission on any other groups than the admin server query....
    Just set the i_permission_modify_power to 75 and the grant value of
    i_channel_needed_join_power to 75 as well. It should work with this
  15. #60
    France
    10
    I have take the value i_permission_modify_power 75 and i have again the error
  1. [Resolved] Channel group / channel permissions affecting server group?
    By Amit86 in forum Permission System
    Last Post: February 1st, 2016, 07:46 AM
  2. Add user in channel group after he creates channel
    By Freakmeister in forum Permission System
    Last Post: September 1st, 2013, 11:29 PM
  3. Replies: 4
    Last Post: July 16th, 2012, 12:55 PM
  4. User with Group and Channel
    By Phoenyx77 in forum Permission System
    Last Post: August 29th, 2010, 10:11 AM
  5. Assign non-default channel group when user joins channel.
    By Morfi in forum Permission System
    Last Post: May 15th, 2010, 08:06 PM
