Results 1 to 4 of 4
    September 2010
    42
    Question Permission Problem
    Hello guys,
    I encoutered the following problem .. and I have no idea how to fix this ..
    So I have set these values for the Server Admin - Group.
    What I thought if I set an value for the flag "Vergabe" ( Grant ) this is the maximum the Server Admins can grant to themselves, Groups, whatever.
    But this seems to be not correct, they can set any value they want. Only if I remove the Grant Flag, they can't set it anymore.
    And now what can I do to prevent Server Admins to grant an higher value than specified there?
    -> Permission ignore is disabled! (b_permission_modify_power_ignore)
    Cyberwolf
    Catalunya
    2,350
    Grant will compare only with i_permission_modify_power
    If i_permission_modify_power is equal or greater that Grant, then you can change the permissions Value, where not all are limited to a maximum Value equal to Grant.
    About b_permission_modify_power_ignore, don't enable this permission. But the group can change permissions, ignoring Grant.
    September 2010
    42
    OK .. this explained a bit ..
    But there is still an question left, can I set an option that Serveradmins can only give to themselves, group, .. an maximum "value" (Power) that I can specify anywhere. Or can I do noting to prevent them from doing this, except removing the grant flag.
    18,394
    i_group_member_add_power and i_group_needed_member_add_power define the maximun and needed power to add a member into a group. These permissions are used for server and channel groups.
  1. [Resolved] Permission Problem
    By Kazanka101 in forum Permission System
    Last Post: May 21st, 2014, 10:59 PM
  2. Replies: 1
    Last Post: September 5th, 2011, 03:03 PM
  3. Replies: 1
  4. Problem with permission need help
    By topbaba2 in forum General Questions
    Last Post: January 10th, 2011, 01:51 PM
