Results 1 to 8 of 8
    December 2010
    Washington
    18
    Solved Hotkey Problem with Overlay
    Using TS3 v 3.0.6 Qt Version 4.7.2. Created a hotkey for advanced > plugins > toggle plugin > ts3overlay. Activating the hotkey does nothing. Also tried creating hotkeys to activate or deactivate ts3overlay and they also do nothing. You CAN create a working hotkey to hide it but not to deactivate it.
    252
    Yep you are right but it's not only a overlay hotkey problem it looks like the whole plugin hotkey section is broken.
    I added this into our bugtracker.
    Thx for your report
    InternalTicketID:TS-950
    December 2010
    Washington
    18
    Just upgraded to v3.4.15 of TS3Overlay and this is still broken. Hitting the hotkeys but still not toggling the overlay on or off.
    2,029
    as MuhChy mentioned this has nothing to do with the overlay itself (or any Plugin for that matter) since the Toggle Plugin Hotkey Stuff is part of the TS3 Client itself and that is what is broken. As long as the Changelog doesn't mention this to be fixed you shouldn't expect this to be fixed.
    18,513
    This should work, since client 3.0.6 has been released.
    December 2010
    Washington
    18
    no. I'm using 3.0.6, with API version 16 on both TeamSpeak and the Overlay. Not working.
    June 2012
    I have the same problem.
    252
    Question
    Quote Originally Posted by aquatonic View Post
    Hm this should work since client 3.0.6 and has nothing to do with the overlay version.
    If i open "Settings > Plugins" and use the "toggle plugin: ts3overlay" button, the plugin will be enabled or disabled everytime i press the hotkey.
    Do you use this hotkey ingame or before you start the game?
    I've tested this while World of Warcraft was running and it worked but i don't know if this works in any case.
    In any case i wouldn't use this hotkey to toggle the overlay ingame, i would use instead the "advanced > plugins > plugin hotkey > ts3overlay > toggle overlay's visibility" hotkey.
  1. Hotkey problem 3.0.17
    By Dark-Raven-77 in forum Windows
    Last Post: August 22nd, 2015, 03:35 PM
  2. [Resolved] Can't set hotkey for TS overlay. 3.7.23
    By haxfar in forum Windows
    Last Post: August 7th, 2013, 10:26 PM
  3. Overlay hotkey (scoll lock) does nothing!
    By darthxaos in forum Windows
    Last Post: February 18th, 2013, 02:22 PM
  4. problem with hotkey...
    By nevil in forum Windows
    Last Post: March 17th, 2010, 05:28 PM
