Results 31 to 45 of 46
  1. #31
    July 2014
    Hi, getting the QT error, so I am assuming this version does not work with TS 3.0.16?
    Any chance of an update?
    Edit: Also tried with 3.0.15, both 32bit and 64bit on Win7 64, but same error.
    Edit 2: Never mind - I downloaded the wrong version. It works fine now
  2. #32
    March 2015
    Hello @silentstorm
    Im a bit stuck with your plugin..
    I installed it, it's visible at my Ts3, but it ain't as supposed.
    I select @settings Mic - Enabled when locking PC,
    But it doesn't work, it still mutes my mic, ignores settings.
    My opinion, might be, because your plugin is supported for 3.0.15,
    the newest version on the market now is 3.0.16, could you maybe give it an upgrade,
    so it will be supported?
    thx in advance,
    Alex
  3. #33
    November 2015
    about new version your pluigin
    Hello @silentstorm
    whether there is an updated version of your plugin?
    I windows 7 x64, Teamspeak version 3.0.18.2
    or indeed take the simple embodiment and the other computer is selected.
    The fact that music is broadcast from a computer and you want it to be blocked, but the sound went.
  4. #34
    2,029
    I managed to quickly compile the plugin with the latest Qt and SDK versions Find the link in the first post. Should work just fine (I hope).
  5. #35
    June 2013
    6
    Could you provide any documentation on how to use the channel changer? I cant seem to enter anything in that box that actually changes my channel.
    Any sort of documentation would be helpful.
  6. #36
    2,029
    It should work with the regular text that also works in the bookmarks for the default channel.
    So basically the channel path separated by /
    e.g. to change to the channel "Battlefield" in the following server layout
    Server name
       Lobby (default)
       Gaming
          CS
          Battlefield
          Battlefront
       AFK
    you'd have to enter "Gaming/Battlefield"
  7. #37
    April 2016
    Does anyone have the latest version the link is down.
  8. #38
    April 2016
    Anyone have this working on TS 3.0.19 and windows 10?
    It does not load for me.
  9. #39
    April 2016
    Swervz
    Quote Originally Posted by DustyBandito View Post
    It is outdated and does not work with newer versions. The links for the working version of the plugin are dead.
  10. #40
    January 2009
    Talca, Chile
    14
    Can i deactivate automute when i lock windows?
    Hi guys, thanks for read me =D
    I have running a MusicBot in Windows 7 x64, but when i lock my account (windows user account), automatically both instances (mine & MusicBot) turn off mic. There is an option or plugin to deactivate this option?
    Thanks in advance =D
    Last edited by dante696; September 16th, 2016 at 07:11 AM. Reason: merged, not without this plugin
  11. #41
    April 2015
    151
    Could you update to API 21 ?
  12. #42
    looks like there is an update as of 2017-02-15 here:
    https://www.myteamspeak.com/addons/f...3-f35dcd772889
  13. #43
    April 2018
    Is there any chance the plugin could be modified to include "remember last setting" rather than the user selecting to choose a specific action?
    e.g.
    Example 1
    Client currently has microphone activated, computer locks and the plugin will re-enable the microphone.
    Example 2
    Client currently has microphone muted, computer locks and the plugin does nothing.
    With the above examples this just requires the remember last setting rather than the user having to choose which action they want to perform which might be different each time.
  14. #44
    July 2014
    Update request
    Hey SilentStorm,
    I know the release of the plugin is a while ago and it was last updated in 2017, but I need a favor.
    You know, I'm in need of this plugin in order to use Sinusbot on WS2019. I am restarting my server frequently and I do have to start Sinusbot manually. Thats not the problem at all, but I have to reload the plugin to get it in working state. So I would like to know, whether it is possible to reload the plugin after its initialization?
    best regards,
    Yannik
  15. #45
    June 2019
    Hi there.
    Will you be looking to update to API23? Currently the current version has stopped working and I use it a lot to talk to people when I'm not at my desk.
  1. [RELEASE] AutoCreate Lua Plugin
    By ungood in forum Client Plugins / Lua Scripts
    Last Post: September 25th, 2015, 04:41 PM
  2. [Release]LoLRandomizer Plugin
    By mJrA83 in forum Client Plugins / Lua Scripts
    Last Post: January 13th, 2015, 05:06 PM
  3. [Outdated] TS3 GroupChat Plugin
    By SilentStorm in forum Client Plugins / Lua Scripts
    Last Post: October 15th, 2014, 01:04 AM
  4. [Rejected] ts3client - pc lock actions
    By Tomas in forum Suggestions and Feedback
    Last Post: August 8th, 2011, 10:07 AM
  5. [Fixed] Mute Buttons do not recognize G19 Plugin Actions
    By vierauge in forum Bug Reports [EN/DE]
    Last Post: July 8th, 2010, 07:05 AM
