Page 1 of 2 12 LastLast
Results 1 to 15 of 19
    April 2012
    7
    Failed to Connect to server. Help
    whenever i try to connect to a server on teamspeak 3 it says "failed to connect to server." info is right, i have port forwarded, i can ping the server, no firewall enabled, fresh install doesnt work, and i have called my ISP to make sure that there isnt a firewall on their side that is blocking me. dont know what else to do so i came to the forums to hopefully have someone who knows what they are doing help me.
    EDIT: i have also tried bypassing my router and plugging my computer straight into the internet, still not able to connect to either the test server or any other ts3 server.
    Texas
    745
    Have you tried multiple servers? Can others connect to the problem servers? Do you have any anti-virus/firewall software that could be conflicting? Could you post a client log?
    April 2012
    7
    I can't connect to any servers, uninstalled/disabled all firewalls and antivirus software. Not at my computer at the moment but I will try to post my client log as soon as I can
    it says this stuff but idk what any of it means. also idk how to disable that emote face but it is supposed to be a colon followed by a lower-case letter o
    4/13/2012 3:23:47 PM Info TeamSpeak 3 Client 3.0.5 (2012-02-15 10:30:01)
    4/13/2012 3:23:47 PM Direct Sound Debug setting timer resolution to 1ms
    4/13/2012 3:23:47 PM SoundBckndIntf Error C:/Users/nick/AppData/Local/TeamSpeak 3 Client/soundbackends/directsound_win64.dll error: NO_DEFAULT_FOUND
    4/13/2012 3:23:47 PM Windows Audio Session Error ERROR (-107 -2147023728): Element not found.
    4/13/2012 3:23:47 PM SoundBckndIntf Error C:/Users/nick/AppData/Local/TeamSpeak 3 Client/soundbackends/windowsaudiosession_win64.dll error: GETTING_DEFAULTAUDIOENDPOINT
    4/13/2012 3:23:47 PM Info Registering plugin command id: {a544dae8-2d7d-4bff-bc84-108fc98a0e6c} appscanner_plugin
    4/13/2012 3:23:47 PM Query Info listening on 127.0.0.1:25639
    4/13/2012 3:23:47 PM Info Registering plugin command id: {40f01e66-886d-4c02-a6d4-9ab1e0f557f5} clientquery_plugin
    4/13/2012 3:23:47 PM Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
    4/13/2012 3:23:47 PM Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
    4/13/2012 3:23:47 PM ClientUI Info Qt version: 4.7.2
    4/13/2012 3:23:47 PM ClientUI Info Using configuration location: C:/Users/nick/AppData/Roaming/TS3Client/ts3clientui_qt.conf
    4/13/2012 3:23:47 PM Input Info Input device name: Mouse
    4/13/2012 3:23:47 PM Input Info Input device name: Keyboard
    4/13/2012 3:23:47 PM ClientUI Info Last update check was: Thu Apr 12 20:58:19 2012
    4/13/2012 3:23:47 PM Info Checking for updates...
    4/13/2012 3:23:52 PM Info Update check timeout
    4/13/2012 3:23:55 PM ClientUI Info Connect to server: 74.86.181.194
    4/13/2012 3:23:55 PM ClientUI Info Checking blacklist
    4/13/2012 3:23:55 PM Info Trying to resolve blacklist server
    4/13/2012 3:23:55 PM ClientUI Info Blacklist check ok
    4/13/2012 3:23:55 PM ClientUI Info Initiating connection: 74.86.181.194:9992 74.86.181.194
    4/13/2012 3:23:55 PM Windows Audio Session Devel DeviceDeleteList::waitForDeletes - enter
    4/13/2012 3:23:55 PM Windows Audio Session Devel DeviceDeleteList::waitForDeletes - leave
    4/13/2012 3:23:55 PM Windows Audio Session Debug WAS:penDevice-enter
    4/13/2012 3:23:55 PM Windows Audio Session Debug WAS Buffer size: 960
    4/13/2012 3:23:55 PM Windows Audio Session Debug WAS:penDevice-leave
    4/13/2012 3:23:55 PM Windows Audio Session Debug WAS::startDevice-enter
    4/13/2012 3:23:55 PM Windows Audio Session Debug WAS::startDevice-leave
    4/13/2012 3:23:55 PM ClientUI Info Connect status: Connecting
    4/13/2012 3:23:55 PM Info Blacklist server resolved
    4/13/2012 3:23:55 PM Info Data sent to blacklist server
    4/13/2012 3:23:55 PM Info Data received from blacklist server: ip
    4/13/2012 3:24:01 PM ClientUI Info Connect status: Disconnected
    4/13/2012 3:24:01 PM ClientUI Info Failed to connect to server, want autoreconnect = 0
    Texas
    745
    You need to put it in code tags rather than quote tags.
    As for your problem; I don't see any errors. It is able to reach the server so I don't think that's your problem. Make sure QoS and DDOS/DOS protection is turned off on your router.
    April 2012
    7
    QoS is disabled. as for DDOS/DOS i have no idea how to check if those are enabled or how to turn them off
    Texas
    745
    it'll be a check box somewhere if your router supports it
    April 2012
    7
    i guess my router doesnt support DDOS/DOS because i cant find it. my router is a WRT54GS by the way. any other things it could be?
    any thoughts? still havent gotten it working
    Texas
    745
    You could try disabling flow control on your network card. Not sure if that will work or not.
    April 2012
    7
    how do i do that? im a complete novice with computers
    Texas
    745
    From this article: http://windows.microsoft.com/en-US/w...ction-problems
    Open Device Manager by clicking the Start button , clicking Control Panel, clicking System and Maintenance, and then clicking Device Manager.* If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
    Right-click the network adapter, and then click Properties.
    Click the Advanced tab, and then click Flow Control.
    Under Value, select Rx and Tx Enabled (in some cases, this might be called Auto or Rx/Tx Pause), and then click OK.
    For the last step, instead of selecting enabled, select disabled.
    April 2012
    7
    disabling flow control had no effect either.
    any ideas?
    Texas
    745
    Have you tried connecting by ip? I might be able to help you through team viewer. I cant think of anything else off the top of my head.
    April 2012
    7
    If you mean entering the servers IP instead of its name, I've tried and it doesn't change anything. What is this team viewer you speak of?
    Texas
    745
    PM me about it.
    November 2012
    So, no solution yet?
  1. Replies: 0
    Last Post: November 1st, 2015, 11:06 AM
  2. Replies: 1
    Last Post: September 20th, 2015, 11:09 AM
  3. Replies: 0
    Last Post: August 6th, 2015, 01:16 AM
  4. Replies: 0
    Last Post: January 3rd, 2015, 07:41 PM
  5. Replies: 12
    Last Post: September 1st, 2014, 05:20 AM
