Results 1 to 5 of 5
    April 2012
    Push to talk does not work, but Voice activation does.
    I'm running Win7 64 bit, and running TS3 in admin mode.
    When going to 'Options' and doing a test, it lights up and works fine. But when going through the Setup Wizard and in the main window, no joy.
    Voice activation works in all places.
    I have no issues with Ventrilo, although I haven't tried any other VOIP programs to see if this happens.
    Any help would be appreciated, thanks.
    _
    Turelle
    2,698
    Hello.
    If the test works fine then verify that in
    Settings --> Options --> Capture --> 'Advanced option' section --> "Voice activation detection while PTT" is deactivated.
    Greetings.
    April 2012
    It is unticked.
    2,698
    Hello.
    If you
    connect to a server,
    in a normal channel (that means 'not moderated'),
    press the ptt key and the light doesn't bright
    then in
    Self --> Hot Key profile --> Verify that there is a profile selected (appears with a check mark on the left)
    if none were selected then select the hot key profile (usually is the 'Default')
    If that works, then
    Bookmarks --> Manage bookmarks --> ... choose your connection ... --> More --> ... in "Capture Profile" select the profile
    Greetings.
    April 2012
    It's lighting up now, the hot key profile did the trick.
    Thanks a lot for your time and help Pota <3
  1. Voice Activation and Push-To-Talk
    By ROFL1 in forum Windows
    Last Post: September 30th, 2015, 09:30 AM
  2. Push to Talk and Voice Activation
    By tazmo8448 in forum Client Support
    Last Post: May 16th, 2012, 06:10 PM
