Results 1 to 4 of 4
    September 2005
    Germany / Dortmund
    1,376
    Solved [pluginsdk] onConnectStatusChangeEvent not triggered
    If my tests went right, the onConnectStatusChangeEvent is not triggered for connections, that are started by a plugin.
    Some example code:
    uint64 newschid;
    if (funcs.spawnNewServerConnectionHandler(0, &newschid) == ERROR_ok) {
      if (funcs.startConnection(newschid, identity, host, port, nickname, NULL, NULL, NULL) == ERROR_ok) {
        //now onConnectStatusChangeEvent should be triggered
      else funcs.destroyServerConnectionHandler(newschid);
    The client will connect to the server, but the callback won't trigger.
    P.S.: The client ui does not recognize this connection as well (no new tab), but I still mentioned this in another thread.
    18,410
    This is no bug. The "connect function" does not work with our current plugin API and will be removed for the next client.
    September 2005
    Germany / Dortmund
    1,376
    Of course, it works, you can open connections with a plugin!
    And sorry, as long as this function is included in the SDK, it's a bug.
    2,029
    Yeah it did work, been playing around with that last year and the connection is made, it's just that no new Tab is spawned and no Devices get opened (the connected Client will show as SPeakers & Microphone disabled).
  1. Serverside triggered bannerrotation
    By Akumu in forum Server Support
    Last Post: June 26th, 2013, 12:51 PM
  2. Replies: 7
    Last Post: September 18th, 2012, 03:01 PM
  3. [PluginSDK] getResourcesPath
    By SilentStorm in forum General Questions
    Last Post: July 2nd, 2012, 06:44 PM
  4. [PluginSDK] Fire onConnectStatusChangeEvent right before disconnecting.
    By SilentStorm in forum Suggestions and Feedback
    Last Post: February 3rd, 2012, 12:21 AM
