Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
  1. #16
    November 2013
    322
ID:	15312 Click image for larger version.
    (You may only attach up to 5 files per post)
  2. #17
    December 2011
    6
    Hey guys,
    i am running Teamspeak 3.1.4 with VLC 2.2.4
    and when i enter the Settings of the Plugin in Teamspeak i cant change to the "Lower Playback Volume" cause when i click on OK it jumps back to "Mute Playback Volume".
    Repeating over and over, when i go back into the Menu it is back to Mute and it also mutes the Volume of VLC completely instead of lowering it.
  3. #18
    2,029
    Quote Originally Posted by JayKone View Post
    Hey guys,
    As long as you can write to the configuration location that should work just fine. Please send (in a private message) me your cloudbreaker.db file (located where your client stores its settings), the plugin version you're using, where you installed the TeamSpeak Client and the latest log file of your client that had the plugin active.
  4. #19
    2,029
    In other news, I finally figured out what my problems were. The Designer was (or is) creating bad files. After reading the documentation again and checking the generated code, I eventually found the issues and was able to fix the generated files.
    Results are somewhat promising so far. Recreated the AutoReply UI yesterday and it looks ok in the themes I tested (including the DarkenTS version on myTS).
    VLC Muter update should be coming this week.
  1. [Release] Auto/Global Mute Plugin
    By Rajveer in forum Client Plugins / Lua Scripts
    Last Post: February 1st, 2017, 09:57 AM
  2. Replies: 1
    Last Post: August 4th, 2015, 05:11 PM
  3. [Outdated] TS3 GroupChat Plugin
    By SilentStorm in forum Client Plugins / Lua Scripts
    Last Post: October 15th, 2014, 01:04 AM
  4. [RELEASE] WMP Mute!
    By tomix in forum Client Plugins / Lua Scripts
    Last Post: April 16th, 2011, 05:25 PM
  5. [Release]Rhythmbox plugin
    By Dominik in forum Client Plugins / Lua Scripts
    Last Post: December 3rd, 2010, 09:06 PM
